kennyspec
How much farther is the ski spindle bolt moved forward compared to stock?
Sportsterdanne
With the assault a-arms its about 5".kennyspec said:How much farther is the ski spindle bolt moved forward compared to stock?
kennyspec
Are you sure the adapter plates will cheat the clutch? I just took my subframe off and the clutch looks fairly close to the stock cast engine plates.
Sportsterdanne
No im not sure
How.much clearance is there between the clutch and the subframe tubes ? The upper tube is the part that is closest to the clutch, it should be closer then any part of the casting.
kennyspec
I will take pics for you tonight
Sportsterdanne
Thanks. Sent you my email.kennyspec said:I will take pics for you tonight
Sportsterdanne
Kennyspec : You got me worried that i missed something, but seeing the pictures you sent made me calm again.
kennyspec
From your pictures I just thought that they were a bit wide and would hit the I side of the clutch. After looking closer at my sled I think you will be fine. Worse case you will just have to grind the plates a little bit.
Sportsterdanne
Continued on the upper part of the bracket, welded some bends to the top tubes.
I ran out of Argon so i have to get some more to finish it, and then i will figure out som way to attach the lower tubes to make the engine mounts more ridgid sideways.
Its been a while since i Tig welded buts its slowly coming back to me.
Sportsterdanne
Made some lower mounts that bolts to the side plates.
Nikolai
Looking good. Did you weigh the Pro front clip?
Sportsterdanne
Nikolai said:Looking good. Did you weigh the Pro front clip?
Thanks ! Any plans for your sled ?
I did weigh it but i cant remember the numbers and i didnt write it down
I will do it again and post it.
Nikolai
My only plans are to tear the sled apart and drop as much weight as possible haha.
Sportsterdanne
Nikolai said:My only plans are to tear the sled apart and drop as much weight as possible haha.
Ok, nothing more than that
Nikolai
It's a long list but the goal this time around is 419 lbs dry. Alot of it will depend on how much free time i have and if I can find a lathe. I'll also be running the new 156x15x3.
