journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Other than the current arctic spell it never go started here. Lowest snow fall in 30 plus years.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Terry, you may want to post that nice video you have of this clutch and the easy adjusting ect....
Also, I believe Terry mentioned Dalton weights(which most of us have in our stock primary) will fit into the pro4.
Dan
Dan
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Clutch looks good being a 3 arm, have you heard or tested if there is any harmonics setting off knock? Like STM 3 arm? I am interested in buying one but I want to make sure. How much does it weigh? Thanks
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
I haven’t had any problems...i believe it weighs the same as the AC team primary.Clutch looks good being a 3 arm, have you heard or tested if there is any harmonics setting off knock? Like STM 3 arm? I am interested in buying one but I want to make sure. How much does it weigh? Thanks
- Apr 14, 2003
- Hessel, Michigan
- Apr 14, 2003
- Hessel, Michigan
Crossfire12
- Feb 13, 2017
Nospro to install on AC 9000 what belt and different clutch puller?
- Apr 14, 2003
- Hessel, Michigan
Install on 9000 the same as the winder, 105 ft. lbs. to seat the clutch, back off and then 48 ft. lbs.
To remove the clutch requires a special puller from Pro 4 Performance.
Belt, you can run whatever belt you wish and the clutch will be setup for that belt. Most of the winder guys are running the stock 8JP or 8DN
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Do you have these in stock?
Crossfire12
- Feb 13, 2017
Can I run the wider cat belt? Don’t care for the narrower belt, See nothing on your web site, how do you order?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
yes I asked Terry this before...just let him know which belt.Can I run the wider cat belt? Don’t care for the narrower belt, See nothing on your web site, how do you order?
Dan
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Any updates on the pro 4 primary? Any others running it?
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Also consider the Tapp, it's a four arm with no weights or spring to buy separately for $1400. I have approximately 4500 miles on it and it's still tight everywhere. Food for thought
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Oh he is because this is what his Team looks likeAlso consider the Tapp, it's a four arm with no weights or spring to buy separately for $1400. I have approximately 4500 miles on it and it's still tight everywhere. Food for thought
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Oh those Team clutches are the bomb!
- 31K
