NLViper
- Dec 17, 2005
- Paradise Newfoundland
- 2008 FX Nytro RTX
2010 RS Venture TF
2014 PRO RMK Assault 800
At the end of last season I was doing some running on a hard packed road with no scratches.
My temp light would come on then I would stop and wait for the sled to cool down and then continue on. This happened approx 4 to 5 times and on the last time I was not far from the truck so I ran with it on for about 5 mins.
Sled seemed to run fine after this just wanted to confirm that this did not do any damage to the sled. I seem to remember reading somewhere that the temp light comes on long before any damage can be done to the engine.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
It should be fine.
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
should be fine, i recommend getting the mtx heat exchanger and flushig coolant and adding some water wetter when u fill it up, if u dont want to see it again. my 08 it would pop on every once in a while. Hoping the mtx exchanger will stop that now.
mach9
Vents in the hood behind the rad worked for me.
There is too much trapped heat over the motor and not much air flow through the rad.
sleddingfarmer
I think the instrument panel vent would probably work really well.
http://oftracing.com/Store/index.php?ma ... cts_id=205
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
I've got the MTX cooler and ModRod vents and I still had the engine light come on once. It was on a cool day after a warm up, so the MTX cooler wasn't seeing much snow. I was running about 80 mph on a cold day, so pretty clear to me that rad can't cut it when It's asked to do the job solo.
I bought a water temp gauge for this year so I can keep as eye on it.
Anyone know what temp the light comes on at?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Did some research on the "Water Wetter", not exactly the best additive for the cooling system. It actually will leave some deposits in the coolant which could be adverse or damage the system. So think about it hard and do your due diligence before adding. Good Luckraginyamaha said:should be fine, i recommend getting the mtx heat exchanger and flushig coolant and adding some water wetter when u fill it up, if u dont want to see it again. my 08 it would pop on every once in a while. Hoping the mtx exchanger will stop that now.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
I have a Phazer but the idea is the same.
By adding a vent to the back of the panel with the rad there will be added air flow. The fan pull the air into the rad but then the air gets all bunched up in there along with the hot oil tank adding heat.
Having a place for the air to go will make a huge difference in the heat exchanging.
mach9
revster said:I've got the MTX cooler and ModRod vents and I still had the engine light come on once. It was on a cool day after a warm up, so the MTX cooler wasn't seeing much snow. I was running about 80 mph on a cold day, so pretty clear to me that rad can't cut it when It's asked to do the job solo.
I have a water temp. gauge.
In my opinion the light comes on deep into the 200F+ range.
I've not seen the light come on at all last year so I don't know the exact # and I don't want to see it that high ever.
I also run a cooler temp t-stat. 125F
The stock t-stat starts to open at 160F but may not be fully open til 170+
In stock trim, when it opens to flow rad coolant, it's too late.
Then it's a real fight to keep the temp down below 200 even when on a trail of decent snow. Soft powder was the only way I could bring it back down to a 185 zone.
The nytro makes it's best HP between 160 and 170 but that means exhaust is somewhat dirty. Yamaha designed the system in stock form to run around 200F, a hotter temp to burn off the dirt and get better emissions.
Vents, t-stat mod I did was to keep the lady sing around 170 most of the time. If I've ever let it idle for even 30 sec. the temp goes up 200+ faster and higher than Courtney Love in a crack house.
revster
- Aug 18, 2004
- La Salle MB
mach9 said:revster said:I've got the MTX cooler and ModRod vents and I still had the engine light come on once. It was on a cool day after a warm up, so the MTX cooler wasn't seeing much snow. I was running about 80 mph on a cold day, so pretty clear to me that rad can't cut it when It's asked to do the job solo.
Solid intel, thanks for posting.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Fan kicks on at 200*F and light comes on at 210*F. These sleds will not shut down from being hot unless you are simply at an idle!
mach9
It's worth noting oil temp. is a play as well.
If you vent in front of the external oil tank, it will cool the oil a little bit too.
revster
- Aug 18, 2004
- La Salle MB
Srxspec said:Fan kicks on at 200*F and light comes on at 210*F. These sleds will not shut down from being hot unless you are simply at an idle!
Allan in your opinion what range should the sled be running in?
NLViper
- Dec 17, 2005
- 2008 FX Nytro RTX
2010 RS Venture TF
All great info guys thanks. mach9 is this t-sat a Yamaha part or where did you pick it up at. Is there any other draw backs to running the dirty exhaust besides damaging the environment?
shadow44
Toss up some pics of the hood venting you did there buddy..
