Radiator fan question
Apex2006
McHenry, IL
Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Does the SW have a fan for the radiator or does it simply rely on air flow and front/rear heat exchangers? Was running a long trail with lower but hard packed snow conditions and it was shutting down because it was overheating. While waiting for it to cool down, never heard a fan come on. Once in deeper snow, was normal. Seems to run hotter than the Viper did.
There is no front radiator like the Viper has. The turbo intercooler is in that spot. All you have is heat exchangers in the tunnel and in front of the track.
Thank you!
Should be running around 172. That's were most are when cooling good and trail running.. I always have the temp display up on the dash. And the Viper usually around 167 if I remember
only went for one ride so far...but is there are way to display coolant temp in degree's and not just the bar across ? Mine seemed to stay a little over halfway to the H
Press and hold the lower left hand button until the numbers show up
Just like drantteiss said
Just wondering, with these gauges doing alot, do they have a MPG mode too? I know im a dork but i like that on the doo.
thnx
Dan
