FLYBYU
So since this thing can pull timing, do i need to do any timing adjustments with the cam gears when i do the head shim.
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
Wow, thats over my head!
I thinking of the ignition to fire the fuel at the right time depending of rpm, tps and boost.
And the cams decides how much air there are to compress.
Generally described!
FLYBYU
Maybe dave from powderlites will chime in on this.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Yes you do, when going with thicker head gasket and/or a head shim you need to move the cam gears at least on the intake cam to make the most power, retarding the intake cam will make more power.
Cam timing have been debated for years in this forum, please make a serch, write cam AND timing and you have something to read about until the end of next week
What TBird says - there is no relationship between what the RB3 does with the ignition timing and the timing of the overhead cams controlling the opening and closing of the exhaust and intake valves in the valve train of your cylinder head.
RB3 ingition timing tells the ECU and coils when to fire the spark.
Cam timing determines when the cams holds the valves open for filling of new charge and disposal of burnt charge.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
FLYBYU said:So since this thing can pull timing, do i need to do any timing adjustments with the cam gears when i do the head shim.
Yes definitety!
Head shim will shift the cams like + 2 degrees... yo uneed to restore it to stock or increase lsa.... by shifting the intake cam back enough
Lococoin
MulotTurbo said:FLYBYU said:So since this thing can pull timing, do i need to do any timing adjustments with the cam gears when i do the head shim.
Yes definitety!
The whole idea of adjusting your cam timing is to remove both the intake and exhaust overlap, not to put it back to its stock setting.
