ThatOneGuy'sBrother
- Oct 12, 2014
- Monroe County Norwalk WI
- 2020 Sidewinder LTX GT 2015 Apex XTX
I thought it was odd when we picked it up. But wasn't too worried as it has never been out on the snow. And jumping on it in the shop is in no way a good test of the suspension, I didn't think much of it. But when I had the chance to sit on two other LTX sidewinders and look at their suspension I figured something was not correct. They do not sit on the couple blocks at all like mine. They have a good amount of smooth easy travel before hitting the blocks. Both of these other sidewinders do not have the 2020 front ends.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Make sure the spring retainers are installed correctly, which is up. Some sleds have come with the spring on the bottom side.
This is the correct way they should be.
DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Drummond Island, MI
- Nope
Our 2020 LTX-GT started out just fine, around 1,200 miles I noticed it was sitting lower on the trail then my 17 SW LTX-LE. By 1,600 miles it was less than a half inch off the transfer blocks empty, on them with a rider. As I previously posted, we double checked the mounting, friction points, both shocks and it was the torsion springs. My wife is 160# so we didn’t want the HD fat boy springs. My dealer suggested the hi-lift springs which have 10 degree more coil but are the same diameter of the originals. Once those were installed, problem solved. We put another 1,100 miles on these and they worked fantastic. Great ride and absolutely no sag. She’s a happy rider.
This is the difference between the SRX torsions and the previous 137” springs.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I tried the Star 5 position cam at 5 , and still sags , and seems bouncy when riding .My wife’s 2020 LTX-GT had the same problem last month. The dealer replaced the rear QS3 pulled and inspected the front rear shock. (No problem) That did not solve the problem, so they ordered new springs. Once installed problem solved. We put in spring # SMA-8JP47-71. Supposed to be a 10 degree more twist in the coil for additional lift. Original diameter. Have put over 1,200 miles on it since then. Working perfectly, no more sag.
8JX-G7473-20 and 8JX-G7474-20 Are the SRX rear torsions
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Would the ones on the right give the sled more up spring ?This is the difference between the SRX torsions and the previous 137” springs.
That spring is from a 600 Transporter.My wife’s 2020 LTX-GT had the same problem last month. The dealer replaced the rear QS3 pulled and inspected the front rear shock. (No problem) That did not solve the problem, so they ordered new springs. Once installed problem solved. We put in spring # SMA-8JP47-71. Supposed to be a 10 degree more twist in the coil for additional lift. Original diameter. Have put over 1,200 miles on it since then. Working perfectly, no more sag.
Yes for sure.Would the ones on the right give the sled more up spring ?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I’m guessing the srx springs are on the left?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I just checking the parts diagram here in Canada and it shows 8JX-G7474-00-00 —
8JX-G7473-00-00 for 2020 ltx gt which are different then srx parts numbers. Srx shows same part numbers as you listed.
Yes but I messed up. The SRX springs are not what is in all the other sled. Deleted that post. 8JX-G7473-00-00 is what is in all the other 137'sI’m guessing the srx springs are on the left?
Yes sorry. So to get a higher rate spring the Transporter spring is probably your best bet but I have not compared them.I just checking the parts diagram here in Canada and it shows 8JX-G7474-00-00 —
WinderFab
- Mar 1, 2009
- Woodbridge, ON
And the srx spring is $160 compared to the ltx spring which is $90
I still think adjusting your ski springs softer will have favorable results unless it is actually bottoming while riding. Personally I like alot of sag which is why I bought the SRX springs but whole different skid on mine.
- 10K
