DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Anyone else have a hard time removing the exhaust bolts?
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
The through bolts came out hard and removed some material. I chased the threads and installed 3 studs. 8 mm x 1.25. Put some anti seize on the other bolts.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
You need a ball end Torx (T50) to avoid any issues (as a couple of the bolts need to be taken at an angle...)
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Sent from my iPhone using Tapatalk[/QUOTE
Yep....still came out hard.
DMCTurbo
- Nov 12, 2005
Of the 6, 1 came out normal, 2 stripped on the way out(I had to apply outward pressure as I unscrewed them), 2 broke and I had to cut one as it seized half the way out. I couldn't turn it back in either. WTF. Tried penetrant and heat. No luck. So now I have 3 to drill out and 2 to retap. Not very happy especially when it's on the turbo.
DMCTurbo
- Nov 12, 2005
And to top it all off I couldn't outrun my buddy on his 09 1200 doo. Not too freakin happy right now!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
do not use ball end unless top quality like maatco or snap on...an easier way is to remove the bit from a socket and use it in a box end wrench...fits in the tight area perfect
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
X2do not use ball end unless top quality like maatco or snap on...an easier way is to remove the bit from a socket and use it in a box end wrench...fits in the tight area perfect
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
...interesting - it worked fine for me. The same way the Yama Techs take em off (ball end torx). Get'em off however you can I guess...
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
And to top it all off I couldn't outrun my buddy on his 09 doo 1200. Not too freakin happy right now.
Are you running an XTX or a BTX?
DMCTurbo
- Nov 12, 2005
Xtx 137Are you running an XTX or a BTX?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Was it boosted?And to top it all off I couldn't outrun my buddy on his 09 doo 1200. Not too freakin happy right now.
DMCTurbo
- Nov 12, 2005
NoWas it boosted?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Wait, the 1200 is 130HP stock. Add a header and muffler and you're at around 150HP. Something doesn't add up here. And replace those stock bolts with hex head bolts.And to top it all off I couldn't outrun my buddy on his 09 doo 1200. Not too freakin happy right now.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
My modded NA nytro will beat a 1200 and my sidewinder plays with the nytro something really doesn't add up?Wait, the 1200 is 130HP stock. Add a header and muffler and you're at around 150HP. Something doesn't add up here. And replace those stock bolts with hex head bolts.
