GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Have a pic?I installed the STM protectors today and they are now covering the rubber hoses. Definitely the way to go if you have not installed your protectors yet. A plus is they can be removed easily, no epoxy involved.
Sent from my SM-T705W using Tapatalk
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
No pics of covering the hose?I installed the STM protectors today and they are now covering the rubber hoses. Definitely the way to go if you have not installed your protectors yet. A plus is they can be removed easily, no epoxy involved.
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
When you spray this on, should you keep it off the heat exchangers?I'm telling you if you spray both sides of the inside of your tunnel with silicone spray you won't get much ice forming. I tried an experiment with my Winder and my Wife's 1200 Doo. I sprayed my Winder real good and let it set. I didn't use anything on her sled. After a weekend of riding her sled had a ton of ice buildup and mine had none. I'm a believer and I will be doing both sleds once a week and before we go on any trips.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Yes. I spray both sides inside the tunnel and then the center. I use 100% silicone spray and put it on heavy. Let it dry and you should be good to go. I also spray the suspension but I'm not too concerned about it.When you spray this on, should you keep it off the heat exchangers?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just sprayed mine down with snow blower teflon spray, same stuff ive been spraying on all my sleds for yrs....im sure it cant hurt but It does still hold ice, i do tap on it when coming out from lunch and much of it falls away.
Dan
Dan
Buckeye
- Lakes Region, NH
The first pic is the front left and the second pic is the gap between the front and rear exchangers. About 2". I could close this by relocating the front screw on the rear strip back a few inches.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Bringing this back around to the top to let you all know that started working on a protector kit for these exposed hoses. Hope to form up a prototype set today. If my idea works, it will be bolt in design using existing fasteners in tunnel and all you will need to do is pull the skid!
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
Hope this “fix” will work and fit for those of us with taller tracks like the 1.75 that came on my sledBringing this back around to the top to let you all know that started working on a protector kit for these exposed hoses. Hope to form up a prototype set today. If my idea works, it will be bolt in design using existing fasteners in tunnel and all you will need to do is pull the skid!
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Good to hear Travis. Im wondering if you will have a upgraded cross shaft like the RR has, Im thinking if we are dropping skid to work on this hose fix, we can replace cross shaft at same time.
Also, have you looked into a seal/gasket for the oil tank? That would be a huge seller!
Dan
Dan
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Dan
I'm exploring a few options for cross shaft. I'm actually leaning towards an upgrade sleeve that can be installed to beef up the weaker, smaller diameter shafts.
As for oil tank seal I thought I had a nice idea, but when I went to fit up the prototype it didn't work.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I think the upgrade for shaft will be great if you can get it ready same time as the coolant hose, that way just about everyone will want them both as they can repair both same time this fall before riding season.I'm exploring a few options for cross shaft. I'm actually leaning towards an upgrade sleeve that can be installed to beef up the weaker, smaller diameter shafts.
I really cant understand why since 2012 cat has not re-engineered the oil tank to have a gasket ect.....Every sled leaks oil after about half a season or so. I dont mind sealing it up once, if that remains good for many seasons, but not sure how long the seal holds. Maybe since I run ROV delete mine wont leak ever again(after i seal it better) as there is no pressure in my system.
Ok keep us posted on cross shaft and coolant protection. Remember some guys saw the entire tunnel bend upward which allows hose to slip off easily, might consider a bracket on top of tunnel across width to keep that from happening too.
Dan
That would work well but a major issue with stock setup is the bolt length. It ends exactly where the sleeves end. That would need to be addressed.I'm exploring a few options for cross shaft. I'm actually leaning towards an upgrade sleeve that can be installed to beef up the weaker, smaller diameter shafts.
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
I ordered the RR parts from Artic Cat and the bolts supplied are longer. They are m10 x ☓ 1.25. The bushings are the same but the cross shaft is thicker between the bushingsThat would work well but a major issue with stock setup is the bolt length. It ends exactly where the sleeves end. That would need to be addressed.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Any news on this
- 6K
