KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Here is what concerns me. If you add oil vapor or venting to a system as you create the fuel map and now you remove that venting oil vapor, would it not lean out the fuel charge? If thats the case then you drastically can lean out a flash that was created under stock conditions.. there some food for thought.
I have logged A/F both with and without blowby hooked up and no change at all to the Air/Fuel ratio. I had to see for myself because I thought the same thing, so I tested it.
