rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
I purchased slydog command skis for my nytro xtx with the full intention of also trying on my winder. The one thing i noticed on both sleds in deep snow the skis rocked back and forth heavily to the point it wanted to throw you off. Both sleds are setup to be light on the front end and have no issues like this running tuners on either sled. On the trail the skis work well ( way to much steering effort for the nytro) zero darting and no pushing in corners. Any suggestion on what to try to stop the rocking in deep untouched powder?
idontknowjack
My thoughts are the profile of the ski is pulling it down for more grip. Command skis are meant for hard pack trails. Maybe should be using Powderhounds for deeper snow. Just a guess.
rev them up
- Apr 3, 2006
I trail ride 99% of the time, only time I am in powder is getting to trail.My thoughts are the profile of the ski is pulling it down for more grip. Command skis are meant for hard pack trails. Maybe should be using Powderhounds for deeper snow. Just a guess.
might need to shim the ski rubbers to keep the tips level or slightly up with the ski in the air. i have this issue with my et410 as it did not come with ski rubbers.
rev them up
- Apr 3, 2006
Thanks, i was thinking that also. They had a slight tip up.might need to shim the ski rubbers to keep the tips level or slightly up with the ski in the air. i have this issue with my et410 as it did not come with ski rubbers.
- 14K
- 43K
