gpxsrx
- Dec 15, 2009
- way to many 2 strokes
Or let it float ? Thoughts ?
Pstn head
I'm thinking of doing the same thing.View attachment 148643 View attachment 148642 Question shim brake rotor disk to tighten up ?
gpxsrx where did you find that shim ?
gpxsrx
- Dec 15, 2009
The shim is not the right size just for reference in picture. But reading more on topic in sidewinder section.I'm thinking of doing the same thing.
gpxsrx
- Dec 15, 2009
https://ty4stroke.com/threads/barn-of-parts-potential-drive-shaft-bearing-lock.156732/
So rotor should not float. Will have to source a shim to tighten up.
gpxsrx
- Dec 15, 2009
gpxsrx
- Dec 15, 2009
Never used loctight hoping for the best set screws tightened up nice and snug.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Do yourself a favor and get the NEW style circlip. The circlip with the holes has been around forever, Cat in theyre infinite wisdom decided to use those Eaton clips.
gpxsrx
- Dec 15, 2009
Part number handy ?Do yourself a favor and get the NEW style circlip.
Bought the pliers for those odd ball snap rings. Thanks Bruce
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
8JP-RAC03-00-00 for the brake rotor. Still looks like Yamaha is using the silly Eaton type clip on the inner one. I had to get the Eaton type pliers in 2012 when Cat first came out with the turbo Suzuki. Also if you take those Eaton type on and off a couple of times, they start to lose theyre memory, as in they dont clamp as tight from stretching. Get new ones if so.
gpxsrx
- Dec 15, 2009
Thanks Swampcat
SeX Viper
- Mar 22, 2017
- Minnetonka, MN
- 2002 SX Viper
2014 SR Viper RTX
View attachment 148647 I just checked rotor installed with calliper installed and I need 0.037 shim washer to take up play.
I have not put mine back together yet (still waiting to get my shaft back from the machinist) but bought a Koyo AS4565 thrust washer. It's designed purpose is to be a race for a thrust bearing so it is hardened which is nice, it also has the same 45mm bore as your bearing so it will fit nice on the shaft. 1mm thick or .0394" so you should be able to squeeze it in there. I am going to put mine behind the rotor (between the rotor and bearing) because the inner race of my bearing wore a groove in the rotor from spinning on the shaft. You can buy them online or pick one up at your local bearing distibutor. https://www.motionindustries.com/productDetail.jsp?sku=00093070
gpxsrx
- Dec 15, 2009
Thank you very much saves me getting my machinist to make me one. Good find. Have a good one. ThanksI have not put mine back together yet (still waiting to get my shaft back from the machinist) but bought a Koyo AS4565 thrust washer. It's designed purpose is to be a race for a thrust bearing so it is hardened which is nice, it also has the same 45mm bore as your bearing so it will fit nice on the shaft. 1mm thick or .0394" so you should be able to squeeze it in there. I am going to put mine behind the rotor (between the rotor and bearing) because the inner race of my bearing wore a groove in the rotor from spinning on the shaft. You can buy them online or pick one up at your local bearing distibutor. https://www.motionindustries.com/productDetail.jsp?sku=00093070
Just remember there has been cases of the snapring coming off. Probably from a seized Caliper piston. New style and old.
gpxsrx
- Dec 15, 2009
Have one on order.Just remember there has been cases of the snapring coming off. Probably from a seized Caliper piston. New style and old.
Steve do you have a part number for 21 top gear bushing ?Yamaha ? Thanks for all your help
No. They don’t sell just the bushing. Have to get whole gear or go aftermarketHave one on order.
