DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Relocated my FPR.
Fleecer
- Jun 13, 2014
- 2019 SRX
Very Nice!!!Relocated my FPR.
DMCTurbo
- Nov 12, 2005
Return line rerouted to the fuel pump cup.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Much better! And return to tank looks good.Relocated my FPR.
DMCTurbo
- Nov 12, 2005
Thanks JeffMuch better! And return to tank looks good.
sledding rocks
nice job . whats your plan to set your fuel pressure at ?
DMCTurbo
- Nov 12, 2005
Thanks. Set at 47 lbs to start as per Mike at TD.nice job . whats your plan to set your fuel pressure at ?
sledding rocks
are all your new upgraded tunes for the new wastegate actutor , indivdual , or juke boxed now ?
DMCTurbo
- Nov 12, 2005
It's all in a jukebox.are all your new upgraded tunes for the new wastegate actutor , indivdual , or juke boxed now ?
DMCTurbo
- Nov 12, 2005
New Prevost Performance top gear bushing installed in my Scott Taylor gear.
justinator
Was that a direct fit into the taylor gear or does he have custom ones for the taylor gears? I thought the taylor gear bushings were a little different…….might be mistaken though.
DMCTurbo
- Nov 12, 2005
Same bushing. The Taylor gear tapers up towards the teeth so he thought he may have to machine the outer edge of the bushing to fit but in the case of this 25 tooth it fits just fine.Was that a direct fit into the taylor gear or does he have custom ones for the taylor gears? I thought the taylor gear bushings were a little different…….might be mistaken though.
justinator
Just tried a dmc bushing and it fit perfectly in my taylor gear! I wasnt sure if it would go far enough because of the taper but I measured it once it was bottomed out and the overall width of the sprocket/bushing is identical to the dmc gear I removed the bushing from. Thanks for posting that hahaSame bushing. The Taylor gear tapers up towards the teeth so he thought he may have to machine the outer edge of the bushing to fit but in the case of this 25 tooth it fits just fine.
DMCTurbo
- Nov 12, 2005
No prob glad it helped you. What size gear did you put it in?Just tried a dmc bushing and it fit perfectly in my taylor gear! I wasnt sure if it would go far enough because of the taper but I measured it once it was bottomed out and the overall width of the sprocket/bushing is identical to the dmc gear I removed the bushing from. Thanks for posting that haha
justinator
Same gear as you, probably wouldnt work on a smaller gear without machining the edge Id imagine.. The bushing sits flat but is quite close to the beginning of the taper of the gear. Im real happy about this. Did 2500 miles on dmc gear last year and bushing was like new, literally like brand new.No prob glad it helped you. What size gear did you put it in?
