Mark F.
- Dec 23, 2020
- Oro-Medonte, Ontario
- 2021 Yamaha Sidewinder L-TX GT
2016 Yamaha SR Viper S-TX 146 DX
Hi guys. I swapped to a set of 5.7 Pilots on my 21 Sidewinder and would like to use my leftover Stryke skis on a 16 Viper 146 with stock Tuners. I used the Sidewinder rubbers on the Pilot skis, so I'm wondering if I can use the Tuner rubbers, or do I need to order another Sidewinder set from the dealer? Any other washers/bolts, etc needed to swap the Viper to Stryke skis?
Thanks!
Mark.
Thanks!
Mark.
I believe so since they worked on your winder they will work on the Viper.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
He has the newer spindles on the sidewinder.
I would check the part number of the rubbers and see if they match up.
Pretty sure the Pad on bottom of spindle is same as it always was at least it is on my 14 Viper and 21 Venom with new Mountain spindles. So should be direct swap. same rubbers.
- 18K
