Super Charger Build Updates!!
smoothride said:
are you moving the skid back an inch so you can get 9 tooth antiratchets in there. I put 8 tooth in to get the clearance because the front arm is so far forward.
I have very little adjustment with my new track and it wont hurt to have it back to allow for more rap on the 8 tooths that I have in there now.
smoothride said:
I talk to gerald at the novi show an said if there is a problem with a justment to go to a 7 inch wheel on the top of the skid for more adjustment.
I have 8" rear wheels already and under power I can still jump the drivers if the track gets a little out of spec.... I would rather have the rap and I am tired of buying stuff from them...lol
smoothride said:
I took the double nut off the adjustment bolts an put a single nut an have lots adjustment now. give that a try.
I have a billet rear offset axle can do much with it .. :o|
Re: More progress
MrSled said:
I finally have the motor in place. I added the new exhaust gaskets from Sledtoys.com, put the super charger in place after routing all the wiring. I added the Ulmer Oil Filter relocation kit and found the only reasonable place to mount the bastard ...LOL :o| ... even though it up high it tucks nicely in place. Once the oil is drained you will have to put a cloth under the filter and be very careful when changing.... way better then taking the Supercharger out to get to the filter.
Nice job! Now hopefully with this combination you will change the oil more often than a motor! LOL!
:drink: ;)!
Re: More progress
:drink: ;)!
LOL, Right!! I never had to change the oil before...LOL
Here is another view of the oil filter, battery and supercharger all tucked in nice and neat. :Rockon:
I needed a oil tank drain and this is what I decided to do. TIG weld a nut to the main tank elbow. But after I install it I did not realize that it would be to tall so now I modded the plastic lower so its even easier to drain the tank and you dont have to remove the lower plastic to do so....LOL
You can also see that I have the brake back on and the air ride compressor in place as well.
I also made a bracket for the PC-V LCD Screen and mounted that to the Muffin Works riser.
I like the oil drain idea... looking Good on the rest of the project. Hopefully ill be going through this process soon..
Keep it up.
Subaru2006
*Update the M20 to Air Assault Package
*Added the new mid pipe and O2 Sensor, slipped the exhaust on....
