tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Agreed.but if the 137 XTX sidewinder is uncoupled that could be a winner
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
AWSOME! I've decided on 129''. Thanks fellows
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
I love my rt-x with 129 and the turbo makes it really come alive. I use very aggressive carbides and it allows me to carry a lot more speed into and thru the corners. https://www.qualipieces.com/en-US/y08-352-06/top-gold-hc-carbide-runnersAWSOME! I've decided on 129''. Thanks fellows
yamaha06
Is there anything that can be done to make the 137 transfer more? Need to make my decision on the rtx le or ltx le sidewinder. My viper is a 137 and I have the 1.6" ice cobra track on it. Seems to hook up good, I don't ride off very often but when I do the sled handles it no problem. It seems to
handle the rough trails pretty good with the shocks revalved and I can imagine with the sidewinder le shocks it will even be better. I just wish there was more ski lift, maybe with the turbo the 137 will have that? Never have rode the rtx so I have no way to compare it to that.
Power and traction give you wheelies but not transfer. Guys here have modded the transfer block setup or removed it all together. Heavier canter shock spring also helps a lot.
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
I was running a 230 hp xf 9000 which is a 137 and I'm going with a 129 rtx le for better transfer. I was running with the bar transfer bar out completely to get transfer. My buddy has a 16 129 turbo cat and has no problem with transfer. I hope the new longer front arm doesn't ruin this for 2017. Yes the 129 will spin more out of the hole but on the trails with studs it should transfer better and be more fun for aggressive trail riding.
yamaha06
How did you find the 137 transferred with the bar removed? Is it safe to ride with the bar removed. I haven't heard about the new longer front arm, do you think it will make the 137 transfer worse? I like how the 137 stays planted through the trails I just wish at times it was easier to get the front end up when you want.
uprider800
- Mar 18, 2016
- winneconne wi
Rode 1200 miles this yr with it removed and all was good. It transfers good with the right gearing. I ran last yr with 21/41 gears and it would pull hard on hills and flat ground. Now this yr I was going for more top end and went to 21/38 and this definitely held back on the transfer due lower gear. No where near as much transfer or as much fun on the trails. I like the stability of the 137 but I want to get that fun back on the trails. A member on totallyamaha mentioned that the rtx was getting the longer front arm for 17 and they weren't sure if this would affect transfer. He said it was to give the 129 more stability.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
BTW...if i go 137'', i'll have to buy a new trailer. MO' money MO' money. I think i'd rather be dialing back extra traction compared to trying to get more...Are you guys gonna make me spend more money? I thought you were my friends.
these guys have spent so much of my money it is unbelievable and I LOVE IT. Ooops did I say that out loud
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Buy a sled or have money. That's the question. I pick sled. Maybe divorce to go along with it.these guys have spent so much of my money it is unbelievable and I LOVE IT. Ooops did I say that out loud
nytro rtx se
- Dec 2, 2008
- Cambridge-Bay,Nunavut,Canada.
- 09 fx nytro rtx se old sled
14 Sr. viper rtx mpi190 old sled
17 sidewinder 137 xtx 300 hurricane
I run the 14 rtx se 129" with 1.25 rip saw 2, studded with 6 & 4 pattern with 1.625 ice chisels running 10" Woody carbides, Corners well don't push at all . I recently took out 2 coupler blocks off and found was better with them off. Rips like a freight train, just wrapped up our sno drags on the weekend 26-0 all miles of smiles.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Very nice. Never tried removing the blocks. 26-0, seems like your doing something right.I run the 14 rtx se 129" with 1.25 rip saw 2, studded with 6 & 4 pattern with 1.625 ice chisels running 10" Woody carbides, Corners well don't push at all . I recently took out 2 coupler blocks off and found was better with them off. Rips like a freight train, just wrapped up our sno drags on the weekend 26-0 all miles of smiles.
nytro rtx se
- Dec 2, 2008
Allen Ulmer did the clutching for best quarter mile set up , he also machined for OD on both clutches set up for 8DN and running 21/41 gearsVery nice. Never tried removing the blocks. 26-0, seems like your doing something right.![]()
The thumbs up goes out to Allen as he did all the tuning all I did was install and drive
- Dec 4, 2014
- 2015 RTX LE- Hurricane Turbo
Ya remove the blocks I did it half.way through the winter. Wow it's a different sled! Definitely do it
- 10K
