Yamisled
- Nov 2, 2022
- Michigan
- Sidewinder
Switching to the Tapp primary this year and looking for some help/guidance on a drag race set up. I know some of you don’t want to spill your secret recipes but any help would be greatly appreciated. There are some threads on this but nothing on drag setups. Snow drags 660’.
Primary spring (purchased mine with black)?
Weight/bolts in the arms and rollers?
Roller size (purchased mine with +1)?
Clicker position? All the same or a mix?
Running customer ramps or stock? If stock what positions?
Secondary set up?
Sled specs: Sidewinder XTX, 325-350 HP tune, running Tapp primary, stock secondary, 21/41 gears, 8jp belt
Thank you for your help! Safe riding!
Secondary set up?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
My dream clutch, well just any billet clutch would be my dream. Sorry not much help here. Good luck, sounds like a beast of a sled!
Maxceleration Racing
- Jul 22, 2019
- Calgary
- 2018 Sidewinder M-TX SE 153
2019 Sidewinder SRX
- Calgary
This should get you close:Switching to the Tapp primary this year and looking for some help/guidance on a drag race set up. I know some of you don’t want to spill your secret recipes but any help would be greatly appreciated. There are some threads on this but nothing on drag setups. Snow drags 660’.
Secondary set up?
Primary
Black spring
+2 rollers (17.5mm)
Set 2 ramps on A side, 2 ramps on B side
For the 2 positions on A side - med bolt, 1 washer on each bolt, 2 set screws per arm
For the 2 positions on B side - med bolt, 4 washers on each bolt, no set screws
Start with all clickers on 3 - fine tune as required
As a general guide - each gram of weight will change RPM by about 40. For example, add a gram of weight to each of a pair of opposing arms will reduce RPM by about 80.
Secondary
37-42 helix
Dalton Black Orange at 6-2
Set anti-lag (launch control) to hold about 3900-4000 RPM and 6-8 pounds of boost.
Hang on.
Yamisled
- Nov 2, 2022
- Michigan
- Sidewinder
Thank you! Very helpful!
A couple questions.
Does extra weight in the roller act like heel weight and arm weight like tip?
Is there a reason/thought process behind with a different weight profile with the A ramp (less roller and more arm weight) than the B ramp (more roller weight, no arm)?
A couple questions.
- Jul 22, 2019
- Calgary
2019 Sidewinder SRX
- Calgary
Haven't experimented with different rollers, that's just the setup I'm using with a similar or higher power level. No real strategy with the different weights on the profiles, and I don't think it would really matter at all. When just adding weight on 2 arms it helps keep things organized. Helps when you make notes as to how much weight you've added or removed from where.Thank you! Very helpful!
A couple questions.
- 20K
