STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Getting ready for a week long trip
Are these marks on the ramps of my TAPP clutch anything I should worry about
Really hard to tell from the pics Rich. Is it just belt dust compressed on the ramp?
Turboflash
- Mar 18, 2019
- Southern MN
Send pics to Tapp and see what they say?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Maybe? I will try to clean them off.Really hard to tell from the pics Rich. Is it just belt dust compressed on the ramp?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Do you do alot of high speed runs at a sustained speed? Almost looks like the rollers are wearing through the hardness of the ramp due to being held at one constant speed IMO.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Not really. Some higher speed trail running, but not sustained speeds at 90 plus
STAIN
- Feb 29, 2004
- Vermont
- Vermont
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
B side raises engagement and is more aggressive shifting.
See n blue
- Dec 10, 2013
- East
- 2017 LTX
How do your rollers look?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Rollers look good. I put bushings in them this fall.
I switched to a plus 1 roller vs. the plus 2 it came with
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Just got back from a 4 day ride.
On day 3, after 600 miles, I heard a strange noise on startup. I thought it was a suspension spring popping the ice out when I sat on it
During the ride I could tell something wasn't right, it was lazy on the bottom and getting a little belt slip also.
Luckily, I had brought 2 clutches and removed the TAPP at the hotel and rode the last day on the heelclicker clutch, which is another story.
I disassembled the TAPP this morning.
The rollers are ok. The spider buttons are worn out, the movable sheeve bushing is worn out, the ramps are starting to pancake, and the arms are a bit loose. Clutch is just plain worn out. I need to send it in for a rebuild, or maybe just buy the tools to do it myself. It's @$400 for all the tools and parts.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Stain, what spring was in there that broke, Black or Blue?Just got back from a 4 day ride.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
black
putz21
- Apr 15, 2013
- Tomahawk, WI
When I ordered my Tapp Roller Spider when they first came out, Tapp recommended the Blue spring as they were having some cases with the Black springs breaking. I actually like the lower/smoother engagement the Blue spring provides.
