GAS
- Feb 21, 2018
- Quispamsis
- 2017 Sidewinder RTX, TD SQ exhaust, TD tune bundle. Dash flash, TD/Dalton clutch kit, 225, 1.57 mega bit studs. Pilot skis.
Anyone out there with high mileage on a TD eco trail tune. Any issues? Codes coming in?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the tune is bullet proof and proven for years...
BlueApexXTX
5000 miles of only smiles.. Running it next year too.. 2017 LTX Sidewinder..12 mpg all day...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
That is a very low boost mellow tune, likely run that on 87 forever.
Fleecer
- Jun 13, 2014
- 2019 SRX
Had Ecotrail all last season and flawless. Bigger tunes get a little better mpg in my opinion.
BlueApexXTX
I was actually running the ecotrail last year 2500 miles, reflashed to powertrail this past season for another 2500. No codes no issues.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I can't speak for ECOtrail but I've ran powertrail and max17 the last 2 seasons with zero issues and no codes.
tony lawhead
- Jan 25, 2017
- kingsley mi
- 2015 viper
running pt sm 250hp tune flawless 2000 miles
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
ECO and turbo force muffler for 5k. No issues. Feel it's a very safe tune and actually getting the same mileage as a 17 Viper.
waldo1
not sure why anyone would run anything under powertrail at 270 - its fine for the crappyest gas u can run. my buddys running a newer 250 tune with stock pipe - runs great but this thing needs a pipe - i consistently use at least a gallon less per fill up. the smallest tune i run now is max 17 at 91 octane 275hp....
Yep, on our North trip I ran PT SM alongside my buddy that had PT SQ. He easily beat me every fill-up.not sure why anyone would run anything under powertrail at 270 - its fine for the crappyest gas u can run. my buddys running a newer 250 tune with stock pipe - runs great but this thing needs a pipe - i consistently use at least a gallon less per fill up. the smallest tune i run now is max 17 at 91 octane 275hp....
waldo1
what does PT SM meen? power trail stock muffler? - and PT SQ??? NOT SUPPOSED TO RUN POWER TRAIL WITH S Muffler - itll make everthing red hot over there... not good
Ben sent me a specific map for PT with SM and another map for PT with SQwhat does PT SM meen? power trail stock muffler? - and PT SQ??? NOT SUPPOSED TO RUN POWER TRAIL WITH S Muffler - itll make everthing red hot over there... not good
GAS
- Feb 21, 2018
- Quispamsis
THANKS everyone. I was thinking the eco tune because of the lower boost, Easier on engine. I run 5000miles a year. Plus I do big runs and sometime have to gas up at lodges in the woods and gas is sometime low octane. I don't want to ruin my engine for a little more HP.
waldo1
if u call ben - theres been no failures on the TD tunes at powertrail 270 because of a lean condition or anything he did - or run a choked up heavier pipe for 263 - i dont think 250 would be any safer - and youll get better mileage with powertrail... and its funner - and add some gear for even better mileage - and ... power trail feels slow now.... just sayen.. actually - go right to the max17 at 91 octane.. ran that as the slowest tune all year, my new slow UP and Canada PG tune - told ben he should make a 100 hp tune - so kids could ride it... or donkey friends would b fun to ride with...
- 17K
