jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Looking for information from those that have run these tunes.. Do these two tunes run on stock fuel pressure or is a adjustable regulator required? From what I have read both run about same boost but the MS 19 is a "lean" version which requires a bigger fuel pump.. I do not have a performance header so looking for info with stock header. Any information is appreciated. Thanks Jon
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
YOU NEED UPGRADED FUEL PUMP AND ADJUSTABLE REG
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I did see that.. That's why I was wondering as I have a upgraded fuel pump. I have the upgraded fuel regulator from Hurricane but its not adjustable(not sure what is better about it then the stocker ??). Have heard a adjustable fuel pressure is needed and also heard it is NOT needed under 300 HP.. I understand why the adjustable is handy and why its nice to have. Sled runs slightly lean or rich you can adjust the pressure to get AFR in line.According to td's website
It is optional for ms20.
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
Probally need to call TD and ask Mike!
I also have fuel pump, no regulator and ms20, but have not run it!
Ms17 has satisfied for now anyways!
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
the pump and regulator are insurance.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
MS20 is a 98 Ooctane tune without fuel pump/regulator.
Turboflash
- Mar 18, 2019
- Southern MN
Then there's always the "X" factor which is what octane is the gas one is buying? Pump says 91 but is it? I know for a fact some places I used to trust are now cheating (sell 87 for price of 91 or last summers watered-down outboard gas). And, some places are cheating but don't know it (supplier is cheating). So IMO an adjustable regulator is almost a necessity to be able to respond to high AFR or deto.I did see that.. That's why I was wondering as I have a upgraded fuel pump. I have the upgraded fuel regulator from Hurricane but its not adjustable(not sure what is better about it then the stocker ??). Have heard a adjustable fuel pressure is needed and also heard it is NOT needed under 300 HP.. I understand why the adjustable is handy and why its nice to have. Sled runs slightly lean or rich you can adjust the pressure to get AFR in line.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i wish some brainiack would come out with test strips.... like used on hot tubs for ph etc.... we could use and catch these fckn crooks who cost us an engine because of fake gas numbers. that guy would make millions
My 2002 SRX was performance massaged "Stock" lol and it had the DCS system on it. The sled was very sensitive to octane and it would flash the DCS light anytime it had less then 91 octane. It was amazing to me how many stations I had filled the tank with so called 91 that flashed the light.
Since then I have become very sceptical about the fuel we purchase...octane cheating is very profitable to the fuel stations, easy to do, and basically untraceable.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
19 & 20 you'll want to mix a couple gals 112+ race gas or more Boostane. Hard pulls will get you lights with our great N WI 91
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
This was my plan. Sunoco 100 unleaded. I’m not planning on staying on these tunes. Might dabble for a day? Pretty sure you know what I’m saying.19 & 20 you'll want to mix a couple gals 112+ race gas or more Boostane. Hard pulls will get you lights with our great N WI 91
Fleecer
- Jun 13, 2014
- 2019 SRX
Imo....MS20 runs richer and is LESS susceptible to knock than MS17 or MS19. Sustained long pulls above 10 degrees are no problem at 95 octane with stock exhaust manifold and a big pump. I wouldn't run MAX 19 unless it was 25 degrees or warmer, or unless you ran higher octane.
Where you need a FP and/or even higher octane is when it gets really cold. At -20 on a long pull, with a CAI, stock header, and a good muffler, I've seen 22lbs of boost. When IATs read -5 and you feed the sled a full can of beans, whoever/whatever is on the side of you ..... will disappear!!
Kanatanon
- Oct 4, 2022
- Pembroke
- 2022 Sidewinder L-TX GT EPS
2008 Nytro
Can you provide link to that page? Can’t find it on the site, looked fora while. ThanksAccording to td's website
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
Multi map ECU TUNE REFLASH bundle for 2017 to 2023+ 998 turbo 200-350HP Ecotrail Powertrail, Max 17 Max Spool 17 - 19 - 20 and Race
multimap multi map tune 4 stage TD turbo dynamics reflash ecu tuning
Scroll thru the pics on top if page!
- 8K
- 13K
