yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Great work looks good
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Lame for sure! lol!...its a good thing you took off that White Yamaha MUSIC tuning fork![]()
Redbeard
- Oct 14, 2011
- IN
The air system fittings are laid out and the remaining solenoid brackets for the rear shock and air dump are complete. All I need to do now is make a bracket to mount the air compressor and I'll be ready to start measuring for the air lines to connect the system together. Not shown is a bleed orifice that will be installed on the dump solenoids at final assembly.
yamadoo
- Jun 3, 2003
All those connections and no leaks you must be good looks good great way to organize
Redbeard
- Oct 14, 2011
- IN
Air compressor bracket is complete.
Redbeard
- Oct 14, 2011
- IN
I ended up spending half a day working with a buddy on his sled. Between his schedule and mine, we decided that NOW was the time to get his sled ready. We changed the engine oil & filter, new chaincase oil and greased everything. We also installed copper exhaust donuts that we won at the Giveaway Ride back in January. Thanks again Tom for an awesome event and thanks again Muffin Works for the copper donuts!
Redbeard
- Oct 14, 2011
- IN
When I made the plumbing for my Apex M20, I ended up with fittings and lines running every direction. That system has proved to be very reliable, but I needed a way to trim down on the number of fittings to make things more simple on the Vector. I've already replaced 3 tee's and 2 elbows with a cross fitting to tie the entire system together in one spot. The cross will mount just above the air compressor by means of a bolt that I tig welded to it. Hopefully I can make it up to the hydraulic shop tomorrow for the lines!
View attachment 120427 View attachment 120428 View attachment 120429 View attachment 120430
WOW.. nice work bud!!
Redbeard
- Oct 14, 2011
- IN
Air pressure gauge mount is complete. I tig welded a 1/8" pipe coupling to a piece of flat stock that hooks on the center brace of my Lake Effect riser. The hook keeps the bracket from turning on the mount. This is the final bracket that was needed to complete the system. It's finally time to start powder coating parts!
...stay tuned!
...stay tuned!
Redbeard
- Oct 14, 2011
- IN
It's a beautiful day to powder coat!
Redbeard
- Oct 14, 2011
- IN
It's starting to come together and look like a sled again.
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
You sir, are an inspiration to all of us!It's starting to come together and look like a sled again.
View attachment 120468 View attachment 120469 View attachment 120470 View attachment 120471 View attachment 120472
Redbeard
- Oct 14, 2011
- IN
The rear bumper and mini cooler protectors are installed. I changed the angle of the rear bumper and used pieces of the factory tunnel extrusions and rubber trim to tie everything together.
yamadoo
- Jun 3, 2003
WOWThe rear bumper and mini cooler protectors are installed. I changed the angle of the rear bumper and used pieces of the factory tunnel extrusions and rubber trim to tie everything together.
View attachment 120474 View attachment 120475 View attachment 120476 View attachment 120477
Again Great work.........................what can we say awesome job hope to see this winter. Yamadoo
- 22K
- 78K
- 8K
