showtime
- Sep 16, 2016
- New Brunswick
- 09 turbo cat
Interested on more about your fuel return set upI bought the Hurricane pump and regulator kit and just installed a return line myself.
I got some installation tips from Mike Knapp.
That PEFI fuel pump upgrade kit is really nice and addresses all the potential issues.
I should have taken pictures...
The Hurricane pump kit came with a grommet and spigot. I removed the short black fuel line that runs from the fuel regulator to the tank then plugged the stock fuel return spigot that's on the top left side of tank, drilled a 1/2" hole in the fuel tank fuel pump mount/access panel right beside the fuel line spigot and inserted the new grommet and spigot. I then ran rubber fuel line from the fuel regulator return line port to the new spigot. I had to modify the tank fuel line bracket to clear the new return line fittings.
The return line now pumps unused fuel right over top of the fuel pump "slipper" helping to keep it full to ensure a constant fuel supply to the pump.
Caution:
You have remove the access panel to do this mod as you have to be very careful where to drill the hole as there is really only one spot it fits properly.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I sent you a pmI have new adjustable Fox riser I do not need if interested. pm me for measurements and a pic if you like.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I second the comment about the BOP cross shaft reinforcer and the tunnel savers. Great upgrades and really strengthens things better than RR upgrades.
MS
MS
RAMSOMAIR
I put the BOP tunnel braces on and both the upper and lower RR shafts and my 2017 with 15000kms is perfect!
Fast
- Sep 25, 2018
would you want to sell your old seat?Awsome!!!
I plan on the adjustable risers also and possibly a mountain seat to help with bad back!
What fuel pump did you go with walbro gss342?
I am looking at pefi pump/ reg kit with return line relocation
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I going to keep it until I know for sure I like the mountain seat for riding!!! But I'll let you know if I decide to sellwould you want to sell your old seat?
My X-TX LE came with the mountain seat and I installed a seat off an SRX. I switch back and forth between them but usually prefer the lower SRX seat for most trail riding. Neither seat is for sale.
I have to agree, I bent a stock shaft, broke the rr shaft and took out my tunnel with it. Rr shaft failed during regular trail riding at about the 3500 mile mark for me. Luckily my dealer got the tunnel replaced under warranty for me. I now have the BOP sleeve over a stock shaft and 2500 miles later I've seen zero signs of wear and zero belief this shaft will have any failures like the 2 stock offerings.Hi yamamarc.
wrapped your headers is not a good idea. Ask your manufacturer....!
RR crossshaft have the same weakness than stock.( bushing)View attachment 154801
You would be a LOT better whit PEFI strong shaft or BOP.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Why are these upper cross shafts breaking ? This is the first year that I've heard of so many of them breaking yet there is so many out there with no issues
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Mine was bent!! Probably from hammering big bumps at high speeds!!Why are these upper cross shafts breaking ? This is the first year that I've heard of so many of them breaking yet there is so many out there with no issues
I remember this season I launched off a hill and landed on another mogul! It hit hard and almost threw me off. I thought for sure something was broke but all was good. And now i found the shaft bent. I am guessing it bent from the impact
Buddy had his cross shaft fail a few weeks back. Needs a new tunnel, drive axle assembly, track, and front heat exchanger.
Insurance is writing the sled off.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I have seen a Lotsssssss of them since 2013..... everybody i know have minimum rr shaft which is just a litle bit strongerWhy are these upper cross shafts breaking ? This is the first year that I've heard of so many of them breaking yet there is so many out there with no issues
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I was lucky to have the bop tunnel reinforcement on it! It have save the tunnelI have to agree, I bent a stock shaft, broke the rr shaft and took out my tunnel with it. Rr shaft failed during regular trail riding at about the 3500 mile mark for me. Luckily my dealer got the tunnel replaced under warranty for me. I now have the BOP sleeve over a stock shaft and 2500 miles later I've seen zero signs of wear and zero belief this shaft will have any failures like the 2 stock offerings.
Great upgrade for little $$$.....
I actually had the external plates riveted into the outside of the tunnel where the cross shaft bolts mount. It stopped it from being more catastrophic than it was/could have been at least. At a minimum it stopped the bolts from pulling completely though the side of the tunnel during my failure.
