DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Hit 2 season goals I set for myself today.
1st was 130mph in 1320 with me on the seat and 2nd was 140mph top speed.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
@Fleecer suspected I was slipping the XS 825 belt with 82gr in the primary so I tightened my secondary to 6-2 and my rpm dropped to 82-8400 rpm. A sure sign that he was correct. I kept pulling weight all day and the sled kept getting faster.
Clutching ended as follows;
Dalton black bronze primary spring
Dalton DTYA1s at 76grams
Dalton black orange at 6-2
Stock 35 helix
XS 825
290 pump gas tune
I knew something wasn't right with you running 82G in the primary. Is that a version #1 B/O as well? If it is, I'd switch to a V2 B/O. V1 is just not enough side pressure and too weak.
I have to run a V2 up at 90 wrap on hi-torque rollers to keep slippage at bay in the secondary. Or use a Cat Dalton white or Purple/Lime. at 9-1 to 9-3 even 0-1. It takes a bit of spring pressure to hold the belt in the secondary on these bigger tunes.
Congrats on hitting your goals.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
So were you also able to out run your bud on the blue winder ?Hit 2 season goals I set for myself today.
The ice must have been ideal , in addition to the clutching changes ?
DMCTurbo
- Nov 12, 2005
We drag raced 3000 feet and we were 1/2 a ski apart. It's crazy how close our 2 sleds are. Totally different clutching between the 2 sleds. My buddy's speedo was reading 145 mph and my dragy read 140mph.So were you also able to out run your bud on the blue winder ?
DMCTurbo
- Nov 12, 2005
Yes you were right when you said something was off. I will invest in the new version spring for next year. Thanks for the advice over the years. Much appreciated.I knew something wasn't right with you running 82G in the primary. Is that a version #1 B/O as well? If it is, I'd switch to a V2 B/O. V1 is just not enough side pressure and too weak.
DMCTurbo
- Nov 12, 2005
sledding rocks
- Feb 11, 2017
- north
- sidewinder
congratulations on these speeds , have u tried max 19 or 20 ?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
It’s all in gearing, we’re the gears the same?We drag raced 3000 feet and we were 1/2 a ski apart. It's crazy how close our 2 sleds are. Totally different clutching between the 2 sleds. My buddy's speedo was reading 145 mph and my dragy read 140mph.
DMCTurbo
- Nov 12, 2005
Thank you. I haven't tried Max 20 yet. I'm still running the stock pump so I don't have Max 19.congratulations on these speeds , have u tried max 19 or 20 ?
DMCTurbo
- Nov 12, 2005
Same gears I think.It’s all in gearing, we’re the gears the same?
sledding rocks
- Feb 11, 2017
- north
- sidewinder
to run max 20 safely on 94 long distance u would need pump and fuel reg set at 48 psi , alittle more extra hp . lol , the 22/37 gearing is a great combo for speeds , these same setup were seeing also over the 140 mph mark with Tapp clutching and stock secondary ,Thank you. I haven't tried Max 20 yet. I'm still running the stock pump so I don't have Max 19.
DMCTurbo
- Nov 12, 2005
Max spool 17 is such a great safe tune I think I'm just going to stay with it. I've seen what can happen when you keep pushing more and more boost.to run max 20 safely on 94 long distance u would need pump and fuel reg set at 48 psi , alittle more extra hp . lol , the 22/37 gearing is a great combo for speeds , these same setup were seeing also over the 140 mph mark with Tapp clutching and stock secondary ,
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Great read, DMC.... congratulations
DMCTurbo
- Nov 12, 2005
Thanks. Have come along way over the years.Great read, DMC.... congratulations
TikTok - Make Your Day
vm.tiktok.com
