beeze455
- Nov 23, 2010
- Bowdoinham, ME
- www.gopherdesign.com
Doing more research on the cf skid vs the M skid. The part numbers for the front and rear arms are the same for many sleds. The rear float is 16" and is the same for just about everything. Where things are different are in the front shock. CF have 1704-747 and are 12.51", M's (even the 141 m's) use 1704-351 but size was not given on microfiche site. the hcr does use a different front shock also.
Hmm. Here is some data.
The front arm on skid(1704-720):
2008 M1000 EFI "162" SNO PRO LIMITED EDITION - REAR SUSPENSION FRONT ARM ASSEMBLY SNO PRO NIGHTFIRE LIMITED EDITION
2008 M8 EFI "153" SNO PRO LIMITED EDITION - REAR SUSPENSION FRONT ARM ASSEMBLY SNO PRO NIGHTFIRE LIMITED EDITION
2009 CF8 LE SNO PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2009 CF1000 LE SNO PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2009 M8 153 LE SNOW PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2009 CF8 SNO PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2009 CF1000 SNO PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2009 M8 153 LE SNO PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2009 CF1000 - REAR SUSPENSION FRONT ARM ASSEMBLY
2010 M8 153 SNO PRO LE - REAR SUSPENSION FRONT ARM ASSEMBLY
2010 CF8 LE - REAR SUSPENSION FRONT ARM ASSEMBLY
2010 CF8 SNO PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2011 CF6 EFI - REAR SUSPENSION FRONT ARM ASSEMBLY
2011 CF8 SNO PRO - REAR SUSPENSION FRONT ARM ASSEMBLY
2011 CF8 - REAR SUSPENSION FRONT ARM ASSEMBLY
The rear arm on the skid (1704-722):
2008 M8 EFI "153" SNO PRO LIMITED EDITION - REAR SUSPENSION REAR ARM ASSEMBLY SNO PRO NIGHTFIRE LIMITED EDITION
2008 M1000 EFI "162" SNO PRO LIMITED EDITION - REAR SUSPENSION REAR ARM ASSEMBLY SNO PRO NIGHTFIRE LIMITED EDITION
2009 M8 153 LE SNOW PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF1000 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M8 153 LE SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF8 LE SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF1000 LE SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF8 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF1000 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2010 CF8 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2010 M8 153 SNO PRO LE - REAR SUSPENSION REAR ARM ASSEMBLY
2010 CF8 LE - REAR SUSPENSION REAR ARM ASSEMBLY
2011 CF8 - REAR SUSPENSION REAR ARM ASSEMBLY
2011 CF6 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2011 CF8 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
Rear float shock -16" (1704-813):
2009 M8 153 HCR - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M1000 153 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M1000 LE SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M1000 162 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M8 153 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M6 EFI 153 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF1000 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M1000 LE SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M1000 162 - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M8 162 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M1000 162 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M1000 153 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF1000 - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M8 153 HCR - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M1000 162 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M1000 153 - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2009 M8 153 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M1000 153 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M8 162 - REAR SUSPENSION REAR ARM ASSEMBLY
2009 M6 EFI - REAR SUSPENSION REAR ARM ASSEMBLY
2009 CF1000 LE SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M1000 162 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2010 M8 153 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2010 CF8 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M8 162 - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M8 153 - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M8 162 - REAR SUSPENSION REAR ARM ASSEMBLY
2010 M8 153 HCR - REAR SUSPENSION REAR ARM ASSEMBLY
2010 M8 153 HCR - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M8 153 SNO PRO LE - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M1000 162 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M8 153 - REAR SUSPENSION REAR ARM ASSEMBLY
2010 M8 162 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
2010 CF8 LE - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M8 162 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M8 153 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M6 EFI 153 - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2010 M6 EFI 153 - REAR SUSPENSION REAR ARM ASSEMBLY
2011 M1000 162 SNO PRO - REAR SUSPENSION REAR ARM SHOCK ABSORBER
2011 M1000 162 SNO PRO - REAR SUSPENSION REAR ARM ASSEMBLY
Ok so lets start with the common item. The rear 1704-813 16" fox float. It is used on everything that I can see except the 2011 sleds--2011 still has a 16" shock. I am going to research some skid options that are black because colors throw off the part numbers.
2010 CF8 SNO PRO
Front Arm 1704-720 ARM,FRONT-W/PIVOT (BLK)-FAB
Front Shock 1704-747 SHOCK, FRT ARM-12.51 (FOX)
Rear Arm 1704-722 ARM,IDLER (BLK)-FAB
Rear Shock 1704-813 SHOCK,FLOAT- 16"- REAR ARM-ASSY
2009 M8 153 SNO PRO
Front Shock 1704-351 SHOCK,FRT ARM-ZERO PRO (FOX)
2011 - CF8 SNO PRO
Rear Shock 2704-022 SHOCK,FLOAT-16"-REAR ARM-ASSY
Ok, so these skids are the same minus the front shock length and something on rear shock in 2011.
Now lets start cross referencing colors on the arms.
Black Front Arm 1704-720
Orange Front Arm 1704-598
Green Front Arm 1704-644
Platinum Front Arm 1704-750
Black Rear Arm 1704-722
Orange Rear Arm 1704-603
Green Rear Arm 1704-646
Platinum Rear Arm 1704-752
So the arms are the same. Front shocks are different, but the HCR actually uses the same one from a 2002 ZR. I wonder if the mount points on the rail are the same. I am thinking they are the same from research on the net. Change my tunnel mounts to be the same as OTM or more like an M. Change the shock to a 2002 ZR. Hmmm...
2010 CF8 SNO PRO
2009 M8 153 SNO PRO
2011 - CF8 SNO PRO
