MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
blueironranger said:Adding washers raises the belt, removing lowers it. I had to remove all the washers to get the fresh belt to ride low enough. Also the tips of the 3 bolts are known to wear and cause the belt to ride too high.
Thanks makes sense now. I removed them and belt rides just perfect, a hair above the sheaves. Goes into reverse much better now of course.
I kept stating earlier that I went with a 3-2 wrap 50*, I am dislexic and I meant 2-3 (2 on sheave, 3 on helix) damn this setup just rips! aside from track the clutches are the #1 mod for performance Id say. I am running the Ulmer arms, and may have to add even more weight to them. Running the 50* wrap and using ulmer weights I have put in 3.1g to the heel and 0.8 gram to the tip. I think just a touch heavier in the tip and Ill be perfect, might have to go 3-3 with that. 11,500 hardpack and 10,900 in deep snow.
I assume going to the 60* wrap will help keep rpm up in the deep snow?
