Threads intake manifold
stickyfingers
Piteå
Sweden
Sidewinder 153 MTX -19
Does anyone know what threads the nipple for the hose to the roll over valve has ?
I don't know of anything on or in the ROV system that is threaded or uses threaded nipples. It uses 5/8" hose I know. And you dont want to use heat hose either. It has to be made for fuel and/or oil.
I was thinking of the threads of the nipple 8KJ-14251-00 attached to the manifold,o rmaybe it is attached in another way?
No clue what threaded nipple you’re talking about. Have a photo? The ROV does not attach to an intake manifold.
Here @stickyfingers, this may help...
Yes, my thought was if that nipple could be replaced by a threaded plug and therfore I would like to know what thread teh nipple has
That part has nothing to do with the ROV. That line goes to the boost sensor.
That black hose attaches to the intake infront of the turbo on part #43. If it was attached to #20 it would blow off from the boost when you squeezed the throttle.
If yr talking about the nipple next to the turbo on the plastic crossover intake tube from the air filter. I just put a rubber cap on it
