Alsim
- Oct 6, 2014
- LTX SE 2018
Hi Shagman ! Whit the TP orange secondary ...3-2 wrap or more weight to lowered nearly 150-200 rpm?Make sure that orange secondary spring is wrapped at 3-3. Wrapping 6-1 will increase rpms. You might even try 3-2. I don’t like to adjust rpms with helix wrap but the orange spring is stiffer than the midnight blue and requires less wrap to achieve the same force.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Yes it will lower rpms. Remove some tip weight to get rpms back.
Sent from my iPad using Tapatalk
Alsim
- Oct 6, 2014
- LTX SE 2018
Sorry Shagman I'm not clear. I want to lowered rpm a little but I'm not sure what is the best way . 3-2 wrap or more weight ? It's for n/a viper with Evo stage 4 .... Actually I have 3-3 wrapYes it will lower rpms. Remove some tip weight to get rpms back.
shagman
Vendor
- Feb 18, 2014
How are your weights set now.
shagman
Vendor
- Feb 18, 2014
Will need to add some to bring down or try 3-2 as it may work better there.
Alsim
- Oct 6, 2014
- LTX SE 2018
It's another world ...I have a PB 80 power block clutch ....but I could put more weight. If the TP orange have enough side pressure I think I will try 3-2 wrap ...but not sureHow are your weights set now.
shagman
Vendor
- Feb 18, 2014
Try 3-2 first. It’s probably easier. How do you like that clutch.
Alsim
- Oct 6, 2014
- LTX SE 2018
I like it. Very efficient clutch , easy to tune and realiable without dishes noise. I can push hard 49/45 helix with midnight blue secondary. Now , I try with the Tp orange if it's work better for me.Try 3-2 first. It’s probably easier. How do you like that clutch.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
I finally had a chance to do some wide open pulls on the lake today with the TP Orange spring wrapped at 3-3 with the additional weight I put in a few weeks ago. Hit 105 mph on GPS today, so very happy! Love the TP setup.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
putz21, have you done anything else to your clutches other than the TP parts? I'm looking into that setup...
rx1 fern
Wonder why everyone is getting these good speeds and I have 2 viper ltx and can’t get over 95 mph .
Just have to hit rpm on top for top speed and then conditions play the biggest factor. Find yourself a nice stretch on a lake,river or even road and it will do it.Wonder why everyone is getting these good speeds and I have 2 viper ltx and can’t get over 95 mph .
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
Why do you want the belt below secondary?Yes extra in heel will help revs. 8 jp belts loose performance the longer you run them. New belt will help. Make sure you break it in easy for 30 miles or so. I ran gates carbon on my viper and was very happy with them. They also last longer. If you do try the gates do not set deflection above the edge of secondary. Keep it 1/16” below.
rx1 fern
I also have a backcountry 1.75 . What’s the best rpm to get these speeds . 137 track . It’s pulls good just not seeing the speeds most are seeing .Just have to hit rpm on top for top speed and then conditions play the biggest factor. Find yourself a nice stretch on a lake,river or even road and it will do it.
Depends on your mods. You need to clutch above and below your top speed. 9-9100 is best for most. With that track I think you are doing very well if 95mph.I also have a backcountry 1.75 . What’s the best rpm to get these speeds . 137 track . It’s pulls good just not seeing the speeds most are seeing .
- Locked
