thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Lonn made it sound as the Gates belt would outlast the 8JP and that the 8Jp would put off a fine rubber mess that would stick to everything under the hood. I am returning the 8jp from the sled purchase and buying the gates on his advise. getting gates for same price as 8jp.The Gates Carbon Cord belts work well for performance and consistency....I ran them on the cat, the doo 1200 loved them. But the cat could eat them fast. They are a softer belt aimed at performance. Dont expect it to last any longer then a 8JP. Similar in cost too. But Gates comes with a 1 yr warranty so you can get a new one.
I believe the way to go is to run the MUCH CHEAPER 8DN($55) for trail riding day to day....Pile the miles on the cheaper 8DN and set your deflection up so it rides like a DOO belt, Top cogs over the 2ndary. Then run the 8JP for radar runs and any time you need all your top speed. 8DN is a very hard belt, compared to others.
What I hope for more then anything...is the clutching works properly, efficiently so the belt life is back to Yammie type expectations...Glide washers IMO are a MUST for any setup, even stock....Since the stock LONG primary spring tended to BREAK last yr due to binding(over 3000 miles or so)....Clean up those spring seats in primary, add 2 glide washers(Lonn sells them) and likely cure that issue.
Dan
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Thanks Ken. Like I said I may end up ordering one later. For now I will go with the stock helix and when I go 33/35 I will have something to compare it to.JOE,get the helix it just helps get on boost sooner and in the deep the back shift with a 137 is much better .It's not revy if you feel it is ,add weight to the ramps ,simple .ENJOY
krm
- Apr 22, 2016
- ny
There won't be any to be had then .The sled should of had a 33 to begin with .The 129s are ok ,the 137 and longer suffer down lowThanks Ken. Like I said I may end up ordering one later. For now I will go with the stock helix and when I go 33/35 I will have something to compare it to.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Guys,Dalton has some nice selection of reverse angle helix,s,cheaper to. His are 33/37
35/37
35/39
32/38 and maybe one or two more.i think he also has a 32/36 that one I may try first.
35/37
35/39
Turbo 998
- Mar 30, 2016
- LeSueur MN
- 2017 Yamaha Sidewinder LTX LE, 2014 Yamaha Viper LTX, 2001 Arctic Cat ZR800, 2- Yamaha SS440, Yamaha Enticer 250, Scorpion lil whip, Scorpion Super Stinger
- yes
I want to give a shout out to Shagman and Nos-Pro!! I finally got to meet them yesterday at the Thunder Products booth at Hay Days and they helped me hugely on the a Thunder Products Big Venom clutch kit and orange secondary spring it sure is nice to have guys explain stuff to you and not make you feel stupid when you ask questions and while they're explaining it to you!! Thank You guys!!!
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Terry and Tim are great they test, ride and race the products and know they work and why they work.
Byam
Any Canadien distributors?
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Yes orp in Ontario, I think they were $449,they have an ad on kijiji
https://www.kijiji.ca/v-snowmobile-...viper-and-sidewinder-at-orps-parts/1228432778
XP123
- Dec 25, 2016
- Chautauqua NY
OK Ken I have the helix coming now also. I better stop reading all this stuff on here because it's costing me too much money.There won't be any to be had then .The sled should of had a 33 to begin with .The 129s are ok ,the 137 and longer suffer down low
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
Does the big venom kit for the sidewinder (V-58) on their website come with the new orange secondary spring now?
Turbo 998
- Mar 30, 2016
- LeSueur MN
- yes
No it does not it like another $30.00. It comes with a orange primary spring though.Does the big venom kit for the sidewinder (V-58) on their website come with the new orange secondary spring now?
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Ok, that's a little confusing as on their website under the V-58 description it says it comes with a secondary spring and makes no mention of a primary spring unless I'm missing something.No it does not it like another $30.00. It comes with a orange primary spring though.
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Quote from website: "Comes with everything you need—Heavy Hitter adjustable flyweights, secondary spring, glide washers, clutch holder, all for only $299"Ok, that's a little confusing as on their website under the V-58 description it says it comes with a secondary spring and makes no mention of a primary spring unless I'm missing something.
Turbo 998
- Mar 30, 2016
- LeSueur MN
- yes
I know when i bought my clutch kit at Hay Days it was an extra @30.00 unless the website is a typo and means primary not secondary because they are both orange. you can call them and ask i guess.Ok, that's a little confusing as on their website under the V-58 description it says it comes with a secondary spring and makes no mention of a primary spring unless I'm missing something.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
The kit comes with the primary spring. Secondary spring is extra. I'll let Lonn know about the typo on site.Ok, that's a little confusing as on their website under the V-58 description it says it comes with a secondary spring and makes no mention of a primary spring unless I'm missing something.
