snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
There website has no mention of there new heavy orange secondary spring for $ 34.00 bucks,so how can I get one soon,i may grass drag my sled with my 38 straight helix,and would like to give it a try.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
Thanks for the confirmation shagman!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks Dan,i guess I did not look hard enough.
swrtxlr
- Jun 29, 2016
- grantsburg
- 17 sidewinder rtx le
07 apex gt
00 srx olins
99 mountain max fully modded
gp 292
mod 292
I just want to give a shout out to Thunder Products. I ordered a spring and helix online yesterday at 10 am and received it in the mail today! Nice Work
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
He is 100% correct. The 8JP is super dusty. I ran one for 200 kms. initially. When I checked my clutches I couldn't believe the mess in there. Cleaned it all up and switched to the Gates Carbon. Very happy with it.Lonn made it sound as the Gates belt would outlast the 8JP and that the 8Jp would put off a fine rubber mess that would stick to everything under the hood. I am returning the 8jp from the sled purchase and buying the gates on his advise. getting gates for same price as 8jp.
- Apr 14, 2003
- Hessel, Michigan
Lonn is a great guy and the service is outstanding!
Jafo1970
- Dec 2, 2016
- oshkosh, wi
- 17 sidewinder, doo 850
Whats the gates part number by chance?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
40C4313 for 8jp length.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I installed all my clutch stuff from Thunder products two weeks ago. The big venom kit with heavy hitters, orange primary spring and glide washers. Also the 33/35 helix and orange secondary spring. Lonn set the weights up on the hitters based on my weight with gear. The last couple days I have had the chance to try it out. I must say I'm very pleased with the performance. Very smooth engagement somewhere around 2800-3000 rpm, quick throttle response and downshifting. Hard to tell on max rpm but the short runs I have had show 8800-8900 rpm. I will know more when I can get some long runs and I will adjust accordingly. I would like to thank those who suggested TP because so far I'm very pleased and would also recommend them.
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
XP, you are stock correct? (no tune and on an XTX?) How did he have your weights set up?I installed all my clutch stuff from Thunder products two weeks ago. The big venom kit with heavy hitters, orange primary spring and glide washers. Also the 33/35 helix and orange secondary spring. Lonn set the weights up on the hitters based on my weight with gear. The last couple days I have had the chance to try it out. I must say I'm very pleased with the performance. Very smooth engagement somewhere around 2800-3000 rpm, quick throttle response and downshifting. Hard to tell on max rpm but the short runs I have had show 8800-8900 rpm. I will know more when I can get some long runs and I will adjust accordingly. I would like to thank those who suggested TP because so far I'm very pleased and would also recommend them.
XP123
- Dec 25, 2016
- Chautauqua NY
yes I'm completely stock except I have a Ice attack track instead of the stock track. I have 3.3 grams in the heel (3/4 allen socket) 2.6 middle (3/8 steel bolt) and 4 grams in the tip (3/8 steel bolt 1 thick washer) My XTX 137" is the same as your LTX LE as far as gearing, drive sprockets and things like that. What made mine an XTX was the track that I no longer have.XP, you are stock correct? (no tune and on an XTX?) How did he have your weights set up?
saskattakman
x2 on the thunder products support...lonn is a great guy to talk to and deal with..would also like to thank nos pro, shagman and dieselxtx for all their advice on the thunder clutching..just setup a friends xtx and engagement is approx 2800 to 2900 and the smoothest engauging sled I've ever rode.
- Apr 14, 2003
- Hessel, Michigan
rxwhopper
anyone ran on btx? found a guy who sold his ltx le 1.75 that bought a big venom kit and sold his sled. was thinking getting for my btx but how much different would weight set up be? btx has 24-50 gearing and 153 2.25 compared to a 137 1.75 and 21-41 gearing? his was set up for 280 and im a bit heavier
- 6K
