Janne339
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
im not sure i see what is different? looks like the same drag link mine has that attaches threw the hole in the bottom of the post....if your talking replace the post im for sure not doing that, parts here a stupid prices...if i can return the play to the factory 10% or so that will be fine. I dont hear any clicking or moving on my post its just that tie rod blockYou see nr 26. New part number. Yamaha update the steering last year in 2017 because of the play I showed in the video. I put in the new one and 90 % of the play is gone.
https://www.yamahapart.com/oemparts/a/yam/55fae34a87a8660fe0572410/steering
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
@savageman69 I’m sure your steering system play has the same source as mine. See the video in this thread for confirmation. https://ty4stroke.com/threads/crash-damage-and-repair-info-and-pics.145856/page-4#post-1480271
Did you end up replacing with the stock bushings, or did you manage to find a source on some Oil lites or something similar?
quentin lemay
- Feb 14, 2020
- ALBERTA
- 2015 Yamaha viper mix 162 mpi turbo
is there any better way to replace bushing #3 in the pic other than drilling all rivets out?
have to do the ones in mine.
thanks.
thanks.
That's the only way. Its worth it though to do the grease mod. 1000's of mi on mine and very little play after.
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
I replaced those useless delrin flanged bushings with two leaded bronze bushings that I used for the top gear. I got my buddy to cut me two stainless 1/16" thick washers, one on top and one on the bottom. Sand the paint of the tie rod crank tube and hone the bushings for a good fit. All play is gone.
I had to hone out the bushings with a 1" flap wheel to get the clearance. I hope it won't seize at -40C.
I also drilled a grease track in the front center and added a 45 deg fitting pointing upward. Cut a fitting clearance hole in the plastic piece out front between the two fins. Now you can grease it when the hood is removed once a year.
quentin lemay
- Feb 14, 2020
- ALBERTA
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
I got the new bushings in and put back together. Still has play.
Any ideas. It’s still in that set up. I can wiggle the shaft a bit.
I assume you put the factory plastic flanged bushing back in. Go back and read my post #21.
Replace with bronze. Remove the paint on the tube and hone the bushings to size AFTER the are pushed in there.
yaa maa haa
- Mar 12, 2017
- SW Ontario
- 2016 RTX-LE
Bikeman Pipe
Big Venom Kit w/2ndary sheave adjuster
911 Primary cover w/sheave adjuster
4th wheel Big Wheel Kit
135 Woody's 1.325
I read this thread too late. Already cranked down on the tie rod bracket pivot bolt, probably crushed the plastic bushings even worse. Still has play, but less. Ordered new bushing, washers and bolt because i was concerned that I sheared the bolt while tightening it. If I have to drill out the steering plate to do the bushing, i may as well upgrade to the reinforced steering bracket.
Which plastic bushing was worse? Top or bottom? I may not drill out the plate to do the top one, only swap out the bottom one. Depending.....
I could try to rotate the top bushing 180° to a lesser worn out position.
Ideas?
Ideas?
- 46K
