UP bushman
SORRY
You can drill your old ones out also just knowing everything is completely new is nice. I drilled out my old ones just noticed they were wore on one side of the Washer more than they other. SORRY I did not know alot of guys wanted these that is when I made the Washers available already drilled. Thanks for the feedback and will do better at communicating just a working guy trying to make something better.
Jeremy
Hey, no hard feeling there my southern bushman. I have good news to share with all of my fellow yamaheads. A brand new Yamaha dealer has just opened here in town, well not till monday, but still awwwwwwwsome news for me !!! I'll have the new washers ordered on monday and all of my warrenty issues will be delt with. It is a blessing to me knowing that a Yanaha dealer is so close instead of being 1200 kms away as most of you from the southern provices and states have access to a dealership by just driving down to it. Well I too now have that luxury !!! LOL I just apprieciate you taking time out from your personal life to fabricate something that makes everybodys ride better !!! Phazer owners anyway. I'll let you know when everything is installed.
Jeremy.
Jeremy.
mx1500
my limiter strap is as loose and evercannondale27 said:No.That would be the skis.Try shimming the skis so they point upward and not flat when front of sled is in air.And check toe out.Final possibility is limiter strap is too tight.
Ruckus
mx1500 said:my limiter strap is as loose and evercannondale27 said:No.That would be the skis.Try shimming the skis so they point upward and not flat when front of sled is in air.And check toe out.Final possibility is limiter strap is too tight.
Wat?
mx1500 said:is this why mines so hard to steer and it just jerks around?
I responded to this mans question.Sorry for going off topic.
Jeremy
Can't wait for mine to show up !!! Just like X-mas !!!
Motoman765
- Dec 12, 2006
- Michigan
- www.teamfsr.com
Just getting back into the snowmobile mode from biking and came across this. I was going to make some of these myself for my sled, but you you just saved me a ton of time and work. Mark a set for me, do you need a PM from me with info?
UP bushman
Hey guys here is what the new Bronze Bushing & Plastic Washer Kit will look like compared to the Factory Setup. It will be sweet not to have to mess with this again.
BombaPolaYama
Will this setup fit the VL? Can you ship to Canada and how much is shipping cost to Canada? So the plastic washer that is still part of the setup is okay? My understanding is that plastic parts are a big part of the problem on the frontends.
Ruckus
I got mine in no time. I think shipping was $10. Well packaged.
UP bushman
Hi there BombaPolaYama you are correct in saying the Plastic is the problem in these sleds and here is why. The Plastic Washers have an extension that goes into the Pivot Assembly from top and bottom that meet each other with a steel collar inside the the two plastic pieces with the bolt through it. The Plastic is the main peice taking the abuse on the Pivot assembly.
The reason the Brass Bushings will work is they are taking the place of the Plastic Washer in the Pivot Assembly. If you look at the image with the new setup you can see the Plastic Washer is only to keep the space between the steel outer washer and the Idler Arm bolted onto the Pivot Assembly. I put these in my sled already and it has no slop.
Yes they will fit into your sled all Phazer Steering Systems are the same. Let me know if your interested $37.00 for 2-Bushings and 4-Plastic Washers + $10.95 shipping to Canada.
UP bushman
Hey Ruckus when will you be installing yours looking forward to feedback.
Ruckus
My new bushings won't be in until wednesday. I'm not gonna bother drilling out then old ones.
BombaPolaYama
upbushman said:The reason the Brass Bushings will work is they are taking the place of the Plastic Washer in the Pivot Assembly. If you look at the image with the new setup you can see the Plastic Washer is only to keep the space between the steel outer washer and the Idler Arm bolted onto the Pivot Assembly. I put these in my sled already and it has no slop.
Thanks for the clarification and info - I may be in touch re an order.
UP bushman
Ok guys I have the next batch of Brass Bushings and Plastic Washers pre drilled for a complete ready to install kit. Contact me for orders and is a cheap upgrade for steering stability thanks.
