Top Speed Runs NA VIPER
Was your top number from this years testing 107 then?
So at this point, can you give us a guesstimate on what you gained in mph from only the driver swap
My guess means nothing but my gut and the amount of weight I added to clutch tells me it had to be something. Will hope more people run that strip and it packs down and see how it goes then. Friday I will go play again for sure. Is a little warm up tomorrow so it should come around. last years numbers were on packed strip. Conditions still kill this sled. Maybe Friday I will bring the tools to suck up the limiters and do some back to back comparisons.
Decided to do the lowering of sled in my nice heated shop. Straps will be sucked up and rear lowered in quest for 110mph. If it shows big gain and 3mph is big at this point I will go back to trail hieght same day and run again.
Well this will be interesting. Took a walk down there after work. Guess will find out if it's fast on ice. They are saying a inch of snow tonight so no excuses! Here is the frozen strip
Limiter is in second to last hole and these red urethane donuts lowered rear about 2". No sag left. Front I put 45psi in floats so that's lowered too. Lift won't fit under it but still has suspension. Any other ideas?
My river is good but have to have studs. Excited! This is a brand new track so stiff as it gets and this thing rolls with two fingers with engine off! Definitely the Introverts reduced drag. Didn't have time to get the studs in yet but will get it done tomorrow and cant wait to hit that river. 106mph last year gps. River should be faster with less snow. Put the same can on I had last year. Little secret mod Ulmer did for me. And these drivers. I will suck the strap up if I have to. Is 110mph GPS possible?
What must I do to gain your trust and be let in on this covert tech???
Well won't be testing by me till snow or it's smoother. Hit 100 real quick but bumps I lost traction. Dangerous so called it for now.
With 4 days of above freezing coming it's going to get ugly really quick. I hate to pack up and trailer north, but it looks like I'm going to have to. I have less than 150 miles so far and it's driving me nuts.
Ever thought of a 14 inch track? They are good for a few MPH for sure
