blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Nice speeds! I’m still waiting for someone to plow a straight road on the lake. With ~6” of windblown snow I managed 89mph today, 88 on my gps. I’m pretty happy with that, my Phazer pulled 74 on the speedo, 68 on the gps about an hour later. The Phazer has gone 85 GPS on a plowed road, hoping to tick the century mark with the Viper.
Orange yellow orangeThis is not listed in the 2 yamaha spring chart... only orange/silver/orange and orange/pink/orange are listed.
Sent from my Galaxy S7
Yamaha
Part#90501-600a5
Here are specs. It is a long spring not short.
https://ty4stroke.com/threads/latest-primary-clutch-spring-specs.147870/
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
Thank! This spring don't have a lot of preload... what is your engagement RPM?Here are specs. It is a long spring not short.
Right around 3000 I believe. It's easily loaded up ramp Into truck or trailer but still hits pretty hard on launch when on it because of the wieght profile. I like it.Thank! This spring don't have a lot of preload... what is your engagement RPM?
Next test should be tues or wed after work. Will leave the current helix on and try the smaller rollers which should allow me to remove some wieght and tune clutch. This weekend the snow was deep and soft nothing groomed or if they were it was quickly covered by new snow. I ran my stock modded can same clutching and lost on average 600 rpm so was always below 8800rpm. GPS says highest speed for weekend was 95mph. more than fast enough to keep up with or lead 2 brand new Cat 9000's and a 18 Doo 850. Conditions slowed us all.
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
Ok then this spring are equivalent to the Barn of parts "soft start spring".....Right around 3000 I believe. It's easily loaded up ramp Into truck or trailer but still hits pretty hard on launch when on it because of the wieght profile. I like it.
I have no idea. Never had one.Ok then this spring are equivalent to the Barn of parts "soft start spring".....
Here we go again. Changed to smaller 14.5 rollers. Thanks DranttelSS!
Looking at the vids I see the reason for the 9211rpm on recall. She spun at over 115mph that run. I am actually right at 9050rpm@107mph. I will try taking some weight out. So smaller rollers were in fact a success. That was only change. Will get there earlier tomorrow. Stupid work always gets in way!
Alsim
- Oct 6, 2014
- LTX SE 2018
Good catch ! Hope 110 mph for tomorrow morning!!!!!!Looking at the vids I see the reason for the 9211rpm on recall. She spun at over 115mph that run. I am actually right at 9050rpm@107mph. I will try taking some weight out. So smaller rollers were in fact a success. That was only change. Will get there earlier tomorrow. Stupid work always gets in way!
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
107@9211 rpm on top went higher with smaller rollers. That’s bad she pulls hard though.
You got to be able to tell a difference on how hard it grabs on bottom!
Oh yes! Never spun that much ever and when it hooked it hooked hard. More screwed up conditions. Now the ice is hard as a rock but hardly no snow other than drifts. Thank god I have good suspension!You got to be able to tell a difference on how hard it grabs on bottom!
Best video I got tonight. Darn glad I had the go pro since tach recall fooled me. Small rollers did exactly as said by Studroes and yammitrip. This will allow me to pull some wieght from the primary. May have to resort to my secret road though unless we get some snow on the river. I don't have enough studs for pure ice.
yammitrip1
- Sep 28, 2017
- Rome ny
That's excatly what my rpms do! Really hooks and it grabs! The engine really works,using all that torque
Youll get that 110 for sure! Skip lunch today!
