bowtietr83
First time working on a slide action and trying to get the top wheels off. I see all the threads about using a puller but how do they press them on/off at the dealer? Does the shaft slide through so I could just put it on my press and press the shaft out of the bearing each way?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
There is a shoulder on shaft behind the bearing so you can't push shaft whole way through from one side.
I typically can drive shaft out of one wheel with a few good shots with a dead blow hammer.
Disregard this post. Saw he had an 06 apex sled listed but didn't realize I was in the sidewinder forum.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I take the whole upper scissor off - undo shock.
Take one of the 'c' channels off the shop press, place the scissor in the middle and then install the other 'c' channel. Place some 1/2 plates sandwhiching the wheel and press the shaft off the wheels. Its easier to have a second set of hands to hold everything where it needs to be - but not necessary.
To reinstall - i have a section of pipe that is the correct dia, and then using a mallet drive it back on shaft. I have seen several procross skids, and the tightness of that bearing on the shaft was different on all 3.
MS
MS
At dealer they have a tool that grabs right on hub backside of wheel and a bolt that drives it off. Very expensive. I use a chisel only hitting on inner race of bearing.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Dealers use this tool.First time working on a slide action and trying to get the top wheels off. I see all the threads about using a puller but how do they press them on/off at the dealer? Does the shaft slide through so I could just put it on my press and press the shaft out of the bearing each way?
https://www.countrycat.com/arctic-cat/arctic-cat-0644-570-idler-wheel-puller-tool-kit
I picked up one of these years ago. Glad I did.
Truly makes life a lot easier with the right tool.
No more expensive than many Milwaukee M18 products.
fourload
I just did mine. I took the circlip off first and popped the wheel off the bearing. Then I used a cheap 2 claw bearing puller to pop the bearing off. The clip can be a bit tricky being it is on the inside.
ToddMeister
- Jun 30, 2003
- Bay City, MI
- Yamaha SR Viper LTX LE
- YAHOO
- tmeister73
I welded a u-shaped piece of steel to a c-clamp from Harbor Freight to make an inexpensive puller.
Byam
I think this is the best bearing fit of this sled.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I think this is the best bearing fit of this sled.![]()
LOL. Far more important than the drive shaft!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Funny.
Ya- they got the tolerance right on that one
Ms
Ms
- 40K
