wot-75
So what must be changed in order to run the 8dn?
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
wot-75 said:So what must be changed in order to run the 8dn?
Just shim the secondary. The three screws on the back side of the secondary. And that's it.
wot-75
YamahaTim said:wot-75 said:So what must be changed in order to run the 8dn?
What size shim? 1mm?
YamahaTim
- Sep 21, 2013
- Farmington, MN
I think so, the ones that are already there. Well the same size as them. Sorry I'm not sure what size they are. I do know that it will be the same size ones that should already be there, now there will be two.
wot-75
YamahaTim said:I think so, the ones that are already there. Well the same size as them. Sorry I'm not sure what size they are. I do know that it will be the same size ones that should already be there, now there will be two.
got it.. thanks
YamahaTim
- Sep 21, 2013
- Farmington, MN
wot-75 said:YamahaTim said:I think so, the ones that are already there. Well the same size as them. Sorry I'm not sure what size they are. I do know that it will be the same size ones that should already be there, now there will be two.
got it.. thanks
No worries! Now go do it and let me know if it works!
Really would like to know
RTX Meirda
anyone try it without shimming secondary?
YamahaTim
- Sep 21, 2013
- Farmington, MN
RTX Meirda said:anyone try it without shimming secondary?
I think a few people have, but not sure the outcome?
loudelectronics
I did not need to shim mine.
YamahaTim
- Sep 21, 2013
- Farmington, MN
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
I didn't need to add shims to my secondary , sitting at the right height.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
When I added the 1 mm shim it was to high.
loudelectronics
Sitting at the right spot about 1 mm above secondary. No belt smoking or grenading yet. I am not going back to the 8jp.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
I'm not putting the stock belt back on either.
YamahaTim
- Sep 21, 2013
- Farmington, MN
Right on...
I done a good thing. I was not even going to post this when my dealer first did this back a few weeks ago or so. I'm glad I did!!
