snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I think the 8jp belt is ok a lot of stock and modstock winders are and have run it w/no problems. But that is the only belt I have blown and it did have 1100 very hard miles when it, when it let go. I must say my xs825 has more miles on it,and still looks new. Either belt works,but the 825 is a sticky belt,and does grab the sheeves better,and will drop rpms some.
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
- 2017 Sidewinder LTX
Well, I guess with all the feed back about the 825, I will get one and try it with the new clutch set up when it comes in. Thanks for the feed back.
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
So I got the clutch kit last night when I got home from work! Will be putting it back together tonight and hope to do some testing this weekend. Instructions say to load the QAY 70 weights to 74 grams. Think I will start a tad lighter and work up if need be. Going to try both the 8jp and the 825 belts for comparison purposes just to see differences in RPM. I will report back, my results.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
What tune are you running?So I got the clutch kit last night when I got home from work! Will be putting it back together tonight and hope to do some testing this weekend. Instructions say to load the QAY 70 weights to 74 grams. Think I will start a tad lighter and work up if need be. Going to try both the 8jp and the 825 belts for comparison purposes just to see differences in RPM. I will report back, my results.
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
Its a 2017 LTX SE with Hurricane 270, Stock modified muffler, CAI, BOV, 1.5" lug track with 144 trail studs, and now a Turbo Dynamics Clutch kit.What tune are you running?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi,yes the 8jp compared to xs825 will keep rpms up around 400 more than 825 belt will. Nice thing about Dalton weights,you can bring set screws along for the trip,and insert them when needed.Can you read what the markings are on the side of the helix? Just wondering what the kit components were?Its a 2017 LTX SE with Hurricane 270, Stock modified muffler, CAI, BOV, 1.5" lug track with 144 trail studs, and now a Turbo Dynamics Clutch kit.
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
The helix is a 35 39. What should I initially load the weights too? The clutch kit didn't really specify. Does 74 grams sound right?
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
The kit didn't come with the helix.The helix is a 35 39. What should I initially load the weights too? The clutch kit didn't really specify. Does 74 grams sound right?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
With the 35 helix I'd be 77-78 G on the 8JP on the 270 Hurricane tune. No Idea why you'd want to use a 35-39 helix on a tuned sled. The 8JP already slips the belt on the topend with the 35.
Try the XS825 belt down around 73-74 G with that helix and see what happens. It a far better belt at gripping the clutches and lasting without blowing on a tuned sled, but it takes a bunch less weight.
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
This sled came with the 35 39 helix in it. I know stock is straight 35. Do you recommend going with the stock straight 35 helix or should I look at something else with my setup?
DTR 82-27
- Dec 22, 2006
- Drumbo, ON
- 2018 SIDEWINDER S-TX DX 137
Those are the exact weights that are working for me. I have Powertrail tune with SQ exhaust and CAI, so right around 270 hp according to TD. Black/bronze primary spring, black/orange secondary spring wrapped to 6-2 and stock helix.
With the 8JP I needed 7.4 grams in QAY70’s to get the RPM below 9,000. I switched to the XS825 and I dropped the weights to 4.4 grams. I tested last week and the sled went to around 9,200 and settled around 8,900.
Also, my offset is between 57.5 and 58 mm (the clutch is not 100% true when I spin it) and I have never blown a belt. I switched out the original 8JP at around 2,000 kms just in case and the current XS825 looks great.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
What are your thoughts about running a lower finish helix with the 8JP? Do you think it would eliminate the belt slip? Something like a 30-32 finish??With the 35 helix I'd be 77-78 G on the 8JP on the 270 Hurricane tune. No Idea why you'd want to use a 35-39 helix on a tuned sled. The 8JP already slips the belt on the topend with the 35.
KnappAttack
- Feb 19, 2004
- Welch MN
It's something I never tried going below 35*, but would think it could possibly help, I went to the heavier Cat springs in the secondary, but never found the consistency I was looking for and have no desire to ever run a Yamaha belt on the SideWinder again.
I tried for years to find something I felt good with using on the Yamaha belts, the heavy secondary springs worked well on certain days, then the temps and conditions would change and the belts would smear and slip again. I was ready to go down and just use the 240 tune and almost gave up on running the big tunes on the trail until I started using the XS825 belt this year. From now on, no more Yamaha belts for me! I just have had no success with them on anything over the 240 tune on my sled. The XS 825 belt just flat out works in all the tunes I have in the bundle, and I no longer need extra pinch in the secondary like I did in the Yamaha belts.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Its old but there's a whole thread on TD clutch recommendations started by Ben.
https://ty4stroke.com/threads/turbo-dynamics-clutch-kit-starting-weight-recommendations.150616/
Last I read anywhere Ben was still recommending a 35º helix.
My OEM 8JP belt went at 2350 miles. My spare was an 8JP which has ~900 miles now. My spare is now the XS825.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
what secondary spring did u end up liking the best ? at what degree ? thanksWith the 35 helix I'd be 77-78 G on the 8JP on the 270 Hurricane tune. No Idea why you'd want to use a 35-39 helix on a tuned sled. The 8JP already slips the belt on the topend with the 35.
- 14K
- 12K
