hiperviper
- Nov 30, 2024
- Fairbanks
- 2015 Yamaha sr viper mtx 153 turbo
Hi everyone new to this form. I just got a Yamaha sr viper and its having a couple issues. It will crank over 3-5+times and then shuts off i do that a couple times and if im lucky it will start If not i hook up a jump pack it starts first crank, thats 60 ish degrees in the garage. When im out for a ride and i shut it of it will not start unless you jump it and even then it takes a few tries. If i let it sit for 20 min it starts on its own first try.
Any help is appreciated thanks in advance.
Whos turbo is on your sled?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
A) replace battery. Could be weak but seem good.
B) replace starter. Aftermarket starters are known to work better than what was in there originally. I just replaced mine in my 2017 NA, and it starts much better. Less than $80 from DB Electric, relatively easy to install through oil filter access panel when oil filter is out for a change. Two bolts and one nut. Toughest part of pushing the starter into position while installing the bolts. Helps to have someone push it in while you insert the bolts.
hiperviper
- Nov 30, 2024
- Fairbanks
Thanks it's a brand new battery but I'll try the starter
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
If you have the ability to swap batteries, it still might be a "bad new" battery. It does happen.
hiperviper
- Nov 30, 2024
- Fairbanks
That's the second new battery i put in and the voltage shows 12.8 on the screen
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Ok, sounds like you have that covered.
hiperviper
- Nov 30, 2024
- Fairbanks
Hopefully the starter fixes things im also going to see if Northern can give me the latest flash
hiperviper
- Nov 30, 2024
- Fairbanks
Tested the starter and it works great. Does anyone have any other ideas
hiperviper
- Nov 30, 2024
- Fairbanks
I stuck the battery on the charger cuz it was at 12.2 volts. when i put the battery on the viper after it was fully charged it went up to 12.7 and with 2/3s throttle it fired to life. Is it possible there is a parasitic drow?
It’s very possible. Could be voltage regulator or maybe just a bad connection.
hiperviper
- Nov 30, 2024
- Fairbanks
Okay do you know where the voltage regulator is
It’s on the nose of the sled. Follow the wire from the mag cover and they will take you to voltage regulator and cdi. It is aprox 4”x4” square with fins on it.Okay do you know where the voltage regulator is
