DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I see Allen is now offering a stage 2 clutch kit, includes STM weights, primary and secondary springs and a helix.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 nytro rtx, 2005 RS Vector MTN turbo
so the other day I was out trying my sled with the Powertrail flash. just curious how my rpm compares to yours? I am currently running Ulmer's clutch kit(60ys) from last year with 2 tungstens on the outer tip and 2 washers on the inner hole, my rpm on acceleration is 9150 and settles at 9050 rpm.
DMCTurbo
- Nov 12, 2005
Similar however I ran the 35/39 reverse and it pulled the rpm down a tad to 8900ishso the other day I was out trying my sled with the Powertrail flash. just curious how my rpm compares to yours? I am currently running Ulmer's clutch kit(60ys) from last year with 2 tungstens on the outer tip and 2 washers on the inner hole, my rpm on acceleration is 9150 and settles at 9050 rpm.
DMCTurbo
- Nov 12, 2005
Oh and my weights are setup the same as you have yours
DMCTurbo
- Nov 12, 2005
You may want to add a gram to pull the rpm down 100 or so, I'd try 1 washer in the middle hole. Ideally with pt you want to be 89-8950ish from what Ben told me last year.so the other day I was out trying my sled with the Powertrail flash. just curious how my rpm compares to yours? I am currently running Ulmer's clutch kit(60ys) from last year with 2 tungstens on the outer tip and 2 washers on the inner hole, my rpm on acceleration is 9150 and settles at 9050 rpm.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Ya I would add 1 gram of weight and see what happens. 8800ish rpm should be the fastest.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
What are you guys running for overall weight in the STM 60YS? I will have to add some as I think Allens spring is lighter then the one Im going with.
thnx
Dan
thnx
Dan
DMCTurbo
- Nov 12, 2005
I'm going to pull one out tomorrow and weight it, I'll get back to ya, maybe tonight if I get a chance.What are you guys running for overall weight in the STM YS? I will have to add some as I think Allens spring is lighter then the one Im going with.
thnx
Dan
DMCTurbo
- Nov 12, 2005
8800 eh, I'd love to see a dyno sheet, not sure if Ben has released any.Ya I would add 1 gram of weight and see what happens. 8800ish rpm should be the fastest.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
The sled should make pretty much the same power from like 8400rpm to 9100ish on the dyno. Theres lots of dyno sheets out there. I think most clutch tuners reccomend tuning to around 9000 rpm in perfect conditions, that way in looser or heavier snow you are still in the peak power band. Alot easier to clutch one of these sleds than a 2 stroke with a peaky power band.
DMCTurbo
- Nov 12, 2005
Ulmer spring on the left, stocker on the right.
80 grams, more weight than I thought.
NYTurbo
What spring are they using in the primary and what' the engagement rpm ?
DMCTurbo
- Nov 12, 2005
Not sure what exact spring it is, It's around a 30/90, engagement is similar to stock, if anything lower than stock but I can't remember. If I get a chance I'll fire up the sled and confirm.
DMCTurbo
- Nov 12, 2005
Engages at 28-2900What spring are they using in the primary and what' the engagement rpm ?
budman 1000
- Jan 22, 2010
- Saskatchewan
ok I'll add a washer in the center and let you know what I get for rpm. One thing I can say is by adding the Powertrail flash my 137 now transfers weight and lifts the skis! haha want lift, simple just add 70-75hp
