![](/styles/admin.gif)
![](/styles/vip.gif)
Is this the same top gear bushing for Winder. You might have said something about it but I missed it.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yes they are the same.Is this the same top gear bushing for Winder. You might have said something about it but I missed it.
I ran one for a complete season and it lasted about the same if not better than the stock bushing. but I had been over tightening my chain.
Go to know. Thanks. I took out a Viper Upper bearing cranking on that chain.. spec works.
![](/styles/TYLifeMember.gif)
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
AA-1110-1 | Oil Impregnated Bronze Sleeve |
16BU16 Sleeve, BU (PTFE Composite),
EXEP161816 | Oil & PTFE Impregnated Sleeve |
BBEP161824 | BB-16 Sintered Iron/Copper Sleeve
I ordered one of each if these. I will check them out when they arrive and decide which on to use. They are pretty cheap.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I did the same on my Viper. It seems that spec is there for a reason......Go to know. Thanks. I took out a Viper Upper bearing cranking on that chain.. spec works.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I tend to agree. How much oil can really get in there, being on top? At least on my vectors and apex the sliding gear was on the bottom, somewhat in the oil. It's pretty much up to the bushing, tension, and it only freewheels in reverse. Theoretically , it should last, even though I'm not a fan of the design.Yes, not sure they do much though.
lilrez
A good read fellas
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I was ruining bushings every 1000 miles on my turbo viper. Tried the 660 bronze bearing and it lasted for 1500 miles last year with one oil hole. I purchased the 15 wide upper gear and chain this year as I wanted to upgrade from the stock 13 wide viper chain. The 13 wide and 15 wide use the same exact bushing so that makes no difference in the life of the bushing as the surface area is equal.
So with the stock bushing and three oil hole upper gear I have over 2000 miles on it this season. About half the time I was above 300hp at 18psi boost pressure so it was a good test. I also have good traction with 1.375” track and around 240 studs.
I used redline shockproof GL5 lubricant it’s equivalent would be something like an 85/140 sae gear lube. This is the same stuff I have used in prior years in the chaincase.
So really the only thing that I changed was my chain tension. Instead of a 1/2 ~3/4 turn out I ran the full 1.5 turns out on the adjuster. Visible slight slack in the chain with the case open.
The results were good, very little wear on the upper bushing, still has the Teflon coating o the inside! I never re-tightened the chain for the entire 2000 miles. It was starting to get a bit loose but nothing that would have caused any issues. I monitored the chain tension by checking the backlash on the secondary from time to time so I knew it wasn’t needing to be tightened.
I’m not giving credit to the extra oil holes for the success and longevity of the bushing. The gear rarely spins on the shaft, only when in reverse will it spin. The damage I was seeing on the bushing wasn’t radial scoring/wear. It was getting worn from being hammered, more of a shock loading type of wear, actually deforming the bushing. Also I have seen tuned winders without any oil hole go for over 5000 miles.
My conclusion is run you chain fairly loose and you shouldn’t have problems with bushing wear. Not sure if it’s because the magnesium case expands more or if these hyvo chains maybe climb on the gears a little when tighter?
Whatever it is, I could care less because now I know.
I was becoming OCD like Steveo thinking my frickin sled wouldn’t go into gear in the middle of BFE because of the dam bushing being worn out halfway through the season!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
![Tsr :rocks: :rocks:](/styles/default/xenforo/smilies/tsr.gif)
So why tell me to run a bronze bushing? Geeze!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Well I feel the 660 bronze would hold up better. AND YOU DONT HAVE TO BUY A WHOLE NEW GEAR TO GET THE BUSHING!
When this one wears out I have another bronze bushing I bought for $3.
![All Coholic :drink: :drink:](/styles/default/xenforo/smilies/all_coholic.gif)
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
if you look up the properties of sae 941 (660 bronze) it has better impact resistance than oilite bronze. Generally speaking oilite bushings are used on parts that reside out side of an oil bath gearcase. I.E. suspension parts, motor bearings, clutch bushings. Regular non-oilite bushings generally are use inside gearboxes.
number1kyster
Part# for the Bronze bushing?
IH8CROWS
It's on gage 14.
Ya gotta keep up. Lol
Although the screenshot is not very readable at all.
theewarrior
Where could I order these bushingsif you look up the properties of sae 941 (660 bronze) it has better impact resistance than oilite bronze. Generally speaking oilite bushings are used on parts that reside out side of an oil bath gearcase. I.E. suspension parts, motor bearings, clutch bushings. Regular non-oilite bushings generally are use inside gearboxes.
