machzrobbie
MCxpress has issued a email to their dealers not to install turbo's on the new motors until there is a solution, not the best business model if there is in fact no issues with the rods. They are in business to sell turbos even on the current year sleds.........................
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Lighter rod = quicker revs. Yamaha is 4.5 pds boost or closer to 170hp not 190 plus.
apexgturbo
- Feb 9, 2012
- terrenceville
- 2008 Nytro,2009 Nytro mtx,2006 apex drag sled
This new engine that Yamaha is trying to make stronger will be cats next step in factory turbo sleds.the reason cats 1100 engine is bullet proof is that it was designed for boost.not one of yamahas engines are designed for boost. This new 2016 engine is thier first step at making a boosted sled motor.knowing what Yamaha is capable of in engine building they will figure it out.Yet the Suzuki 1100 that cat uses in their turbo sleds is the most bullet proof boosted engine out there, that engine in stock form can run twice the amount of boost a yammi engine can in stock form, this is not an arctic issue at all.
Sunvang
- Jan 14, 2009
- Telemark
- Norway
- 2018 Arctic Cat Hardcore EVO
2017 Yamaha Sidewinder BTX LE
Asked Erik at McX if the old crank, rods and pistons will fit in the the engine. Got back that they do, and have already tested this.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
The new rods are not lighter then the old one.
I have looked at the first set that braked over at MCX and they snap in the middle.
Thicker bigend and thinner in the middel.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Are seeing some rumors about a Swedish company that will be making Stonger rods for the Viper. And maybe they will have them ready for delivering in late december
So now it maybe will be a good Christmas for all with late 2016 Viper
Name of the company :http://www.autoverdi.com/rods.html
thamax
So what months is considered early build wise and what would be late? Is there any way to tell motor serial # wise? Or just off month of build?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
read the build date. If your sled is built after 03/15 you have the new engine.So what months is considered early build wise and what would be late? Is there any way to tell motor serial # wise? Or just off month of build?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
On the sticker at the back of the tunnel.
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
Almost held out for a 16 to allow another year to get bugs out of the new machine. I'm really glad I didn't snow check last winter!
Sunvang
- Jan 14, 2009
- Telemark
- Norway
Now that's the can do attitude we like to see!!!Problem solved! Just picked up crank, rods and pistons from a 2014 Viper. Don't have patience to wait for new rods from aftermarket vendor.
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
I think people forget that MCXpress is a vendor to Yamaha similar to MPI is over here. They do not mess around.
Also these rods are not holding up in the new YXZ sxs. Some turbo builders are throwing rods through the cases.
Well, that tells the story. Yxz 1000r and the only kit MPI is offering is only 155hp.
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
Yeah it is likely fine at 155hp b the guys running 8psi plus are the ones having issues.
- 16K
