Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Mounted mine to the handlebars with a homemade bracket. It's up higher towards my chest and my buddy's say they can clearly see it at a distance in the day time.
If I get in the bush deep enough to rip it off, then I'll have bigger problems.
Pic is with my HID's on high beam.
It plugs directly into the factory heated visor plug on the handlebars with an RCA pin that I soldered on.
Heck ya that works! NiceMounted mine to the handlebars with a homemade bracket. It's up higher towards my chest and my buddy's say they can clearly see it at a distance in the day time.
It plugs directly into my heated visor plug with an RCA pin that I soldered on.
that looks like a really good spot. it would mount fairly easy off of one of my handgaurd mounts.
Redbeard
- Oct 14, 2011
- IN
Cannondale-
I'm in the same boat; I don't hand signal anymore. I always try to slow down when I meet other sleds, but more times than not, the other guy keeps it pinned. I feel it's safer to just keep my paws on the bars.
I'm not sure that Ride Lites will ever be universally accepted/used, but I think it's important for the general snowmo-community at least know what they are.
Maim-
I don't have handguards, but the mounts for them should work great! Post pics if you would?
For mine, I split an old 7/8" Polaris handlebar clamp with a bandsaw and used the halves as a base for fastening the light. The light pictured is my older Ride Lite, but would work for Rock's as well.
trail traveler
- Dec 3, 2014
- Everett, WA
- 2015 sr viper s-tx-dx
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
3- 1990's era Arctic Cat prowlers
I purchased some lights from Rock also and have been following this thread for ideas on doing the install and placement of them. I came across this as an option to use, but I'm a bit nervous about making a permanent hole in the plastic. What do you guys think?
Redbeard
- Oct 14, 2011
- IN
Where do you plan on mounting Rock's light?I purchased some lights from Rock also and have been following this thread for ideas on doing the install and placement of them. I came across this as an option to use, but I'm a bit nervous about making a permanent hole in the plastic. What do you guys think?
Could you fasten the RCA jack to the handle bars?
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
The trouble with the handle bars is every time you turn the wire pulls..also lot's of slack around.. I just run the wire in between the panels.. from the left side panel to the wiring coming from the poweroutlet/cigar lighter on the machine. I only have about 6 in of wire showing.. and on coming machines can see it well.
i will post up once i get one to mount up!
on my apex and brothers venture i plan on using the stock heated sheild rca connection on the bars to power the light as they both have rocks power supply on them. on the war it will go to rocks power supply under the bar pad.
Scooter02
- Nov 26, 2007
- Oak Creek, WI
- Yamaha Viper LTX LE
DirtFarmer
- Aug 13, 2017
- Galloway, NJ
- 2009 Yamaha Nytro R-TX SE
I used that type of connector on a previous sled and the rca wires would come off of it very easily. I would use something like this.
https://www.kimpex.com/en-ca/produc...ts/wires/kimpex-universal-single-dc-connector
Sent from my iPad using Tapatalk
Mileage Quest
- Apr 12, 2013
- MPLS, MinneSNOWda
- '12 Apex X-TX
Mine will be mounted on an old mirror bracket... that way I use the factor run rca that’s on the bars... score!!!
sledjunk
- Aug 7, 2007
- Pefferlaw, Ontario
- 2015 Vector LTX 12141 KM
2015 Vector LTX 30736 KM
2012 Vector 20100 KM
2007 Vector GT 30638 KM (Sold)
I made an angle bracket that mounts on the side panel through the three holes with plastic 'dart' plugs on the Vector. The light then mounts to a flat plate that attaches to the angle bracket with a single bolt so that it can swing clear if hit by a branch. I have hard wired a cable that is routed through the third hole in the panel to power the light. I will add pictures tomorrow.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
Great lights for the price.. Wish he had them long time ago.. Takes a Snowmobiler to make a great product for a snowmobiler. Rock uses good connection system,wires and support.
sledjunk
- Aug 7, 2007
I have used home built versions of these since 2007, but decided to buy Rock's version because they are so well designed and built.
sledjunk
- Aug 7, 2007
As promised, here are some pics of my install.
The bracket and the mounting plate are made of 1/4 inch Lexan.
- 12K
