These two came over to do a thorough inspection
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
Today - nothing. Yesterday - rode it
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
I installed seat heaters and digital voltage gauges in both Phazers. I wish I would've taken more pics along the way.
I found a decent sized, water resistant rocker switch for the heaters that's easy to operate with gloves on. So far they seem to work great. High gets a bit too toasty after a bit but I'm not complaining.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
So I have not done much to this sled but it now has big exhaust leak. I did the block off the exhaust with rags and it kept right on running so my guess is the Donuts.
I bought the sled used so I had no idea the guy had already changed them . It had like 2000 miles on it and looked brand new .
So I get two of the three clamps off and the copper donuts look good . So now I need to pull the whole exhaust.
Can I hookup a temp gas tank so I can start it and make sure the flex pipes are good ??
One last problem how to get the third bolt out of the clamps . It’s stripped out . Best to cut the clamp right off or try an easy out ? Happy New Year !
I have turned the tank and used so I could check the flex pipes and you can drill out the hangers and re rivet them.So I have not done much to this sled but it now has big exhaust leak. I did the block off the exhaust with rags and it kept right on running so my guess is the Donuts.
repacked all the bearings on the 11 and discovered that i have to pull fuel tank again as i missed by 1 spline when i replaced the steering blocks. still need to put new scratchers on it as i destroyed one trying to get the tip out to replace it.
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Had my friends '06 Doo in the garage. I pulled the motor out, and tore it to molecules. It needed its crankshaft bearings re-greased at 6000kms. I thought about all the gaskets and bearings and expensive tubes of grease I needed to order. The pistons were bad after a swap 1300kms ago. I got tired so I left. On the way out I glimpsed upon a blue figure in the corner of my eye. There stood a brand new Sidewinder twice as strong, as stunning and ready as ever.
You all know I had to look twice.
DGZRT
- Feb 23, 2006
So got two of the clamps off . On my other sled the Donuts were completely gone or disintegrated when I took the clamps off . Here I believe these are copper but is that gap normal??
RAMSOMAIR
Gap is normal. The clamps pull them together
DGZRT
- Feb 23, 2006
Thanks for the reply . Now I guess I need to pull the exhaust off the back and take a look
finished everything but the scratchers on the 11 and threw it outside. 2016 will be started on when i get home from work at midnight. starting with oil change, checking carbides and swapping scratchers as i put them on wrong side last year when i installed them.
RAMSOMAIR
2016 Viper (daughters) rebuilt rear shock and assembled skid and installed into sled.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Prayed for colder temps and snow in the Adirondacks.
theCATman
