DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I know it's just pricey... Is hurricanes the same?TD has it on their site under TD flasher and data logger
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
More more so than usual - I have the iPad charger wired in under the instrument cluster. So just unplug the main harness and remove the hood.Is there much involved to remove the hood now with TD mount and mini I-pad?
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Yep. Pull gently from the top. There's a video of how to on TD's FB site.So you just pull on it and it pops out?
DMCTurbo
- Nov 12, 2005
What colour were the wires u used to hook it up?More more so than usual - I have the iPad charger wired in under the instrument cluster. So just unplug the main harness and remove the hood.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I meant “no more than usual”. Typo.What colour were the wires u used to hook it up?
I just tapped into the 12v wires to the outlet on the dash and split them. So I have an extra 12v outlet under the instrument cluster. I didn’t want the charging cable up top plugged in. Go for as clean a look as possible.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Nice Beerman.....I run low windows, so if/when I go with something, I will have to make it abit diff.
Im thinking iPhone plus is plenty for size....maybe grab a refurb 6 plus for this.
Dan
Dan
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Hey Dan, I originally thought about using an iPhone Plus too - but you get SO much more real estate with the iPad I really preferred it - the app shows a lot more and works differently than on the iPhone. Plus, when GAP releases their GPS option I'll likely upgrade and run the maps and gauges on the same screen - with all the cool extra performance data that comes with it. The data logging feature plots distance and speed against all the other live values, for someone like you who is a clutching master, I'd expect that to be INVALUABLE.
DMCTurbo
- Nov 12, 2005
Lol pull gently, I was pulling and when she let go I went flying lol.Yep. Pull gently from the top. There's a video of how to on TD's FB site.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
Sometimes they do require good force to pull. Dont be alarmed...
as for the bracket kit...
http://turbodynamics.mybigcommerce....sidewinder-thundercat-zr9000/?setCurrencyId=1
that is USD pricing, click CAN dollar for CAN pricing.
The kit comes with both brackets one for the IPAD one for the Stock gauge, a FAST charger and a Waterproof casing for the Ipad mini4. Best one to get is the LTE version (with cellular connection it's cheap to add to your plan)
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Ben - quick question - did you find that you needed any kind of heating pad behind the iPad in cold temps? I noticed that GAP includes one when you buy their CoPiTrail. And if "yes", where can we buy something like that? I'd think a handlebar heating element would get WAY too hot if wired direct to 12v.Sometimes they do require good force to pull. Dont be alarmed...
Thanks!
NYTurbo
Pretty sure Ben has the heating pads.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Not for my testing. With the charger and the heat from the cab I was fine. But for long trail rides you need it. Because the battery gets too cold and doesn't last long.Ben - quick question - did you find that you needed any kind of heating pad behind the iPad in cold temps? I noticed that GAP includes one when you buy their CoPiTrail. And if "yes", where can we buy something like that? I'd think a handlebar heating element would get WAY too hot if wired direct to 12v.
Thanks!
The heating pad is an option you can purchase. Racers don't need it but trail riders yes.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
You can see one of my customer's trail sled with the Ipad mount setup. He does over 10 000km per season.
He ran 144 mph with Powertrail when I invited him on my test track. 1" hacksaw track 11 tooth drivers and taller gears. He also has STM secondary.
It's a long video but he's in there somewhere.
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- SIDEWINDER L‑TX LE 50TH
- Green Lake Wi
If I ever get my new sled which I’m waiting for them to call! I was looking into the iPad option also. I think a heating pad would be important. I was thinking something like this would work? Any reason why not?
https://www.ebay.com/itm/100X150mm-4-x6-120W-12V-Keenovo-All-Purpose-Silicone-Heater-Pad-w-3M-PSA/271371383851?_trkparms=aid=555017&algo=PL.CASSINI&ao=1&asc=41375&meid=7de1788ba7894532983ae937ffcb9b63&pid=100506&rk=1&rkt=1&&_trksid=p2045573.c100506.m3226
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
Do you have the optional heating pad on the webstore now?
- 9K
