2019 850 X2what year wolverine? we do have a few for some years.
check your pm's.2019 850 X2
Have a wolverine 850 that was rolled and now it has no oil pressure. I remove the oil pressure sensor and oil filter and nothing comes out if I start the engine. Is it possible the oil pump chain has came off?
Has anyone seen this before?
Thanks.
Thanks.
Just updating what I found here.
I removed the oil pipe that connects to the engine in front of and below the starter(which is directly above where the oil pump is in the engine.)
This is the oil supply line from the bottom of the oil tank.
I then removed the oil line on the side of the airbox which comes from the top of the oil tank. Had someone put a small amount of air pressure into it while I observed the other end. With oil flowing I reconnected. Hooked everything back up. Started the engine, have oil pressure now. Code gone.
