Wondering if there is anybody going up to Gary's Yamaha!!!!!!
possessed
Age
62
Sidney ME
2017 Sidewinder LE RTX 129 Curve Skis 1.0 track header tune 280 hp
08 Apex LTX Yamachager
1998 SRX Bender 835
03RX1/ 1993 Thunder Cat
YAHOO
rx11000@yahoo.com
I wish I could go up and try out the Sidewinder at Gary's today !!!!!!! If anyone on here does I think we all would like to hear from you on your thoughts of the Sidewinder ??????? That for any info!!!!!!!
Went over today.....no demo rides, just 2 demos to look at in showroom.
Oh that's to bad but thanks for the info!!!! Was hoping John would of took one out to test!!!!!!!
Me too, would have liked to take one for a rip.
The demos were:
Sidewinder xtx se in blue and white with non coupled skid, 15x141x1.6 cobra track, and fox floats all around. The handle grips on these sidewinders appear thinner/smaller. Although they seem to be more comfortable, the demo had 1300 miles on the odometer and the right handle grip was torn. I hope this is not a sign of things to come.
The other demo was XTX LE in red and white. It had 15x137x1.25 ripsaw and had the fox QS3 Kashima coated shocks all around. These shocks are the real deal. Simply changing the clickers from 1 to 3 was very noticeable in the showroom.
Couple things I noticed: Front clutch resembles the clutches of old, however the towers are wider. The secondary sheaves also resemble the older clutches however the helix is noticeably different and now rides on 3 rollers. Nice setup!! The weights I was told are 84 grams each and the rear helix is a straight 43 degrees.
Aside from that, fit and finish appears to be up to par. The removal of the hood and side panels are quick, easy, and much better than the older cat/viper configurations of old.
Hope this helps.
Great info Thanks for that !!!! I saw them at the Augusta show but so many people around them I do love the looks of the blue Sidewinder If I was going to get one it would be the blue 137 with the Race shocks for sure !!!!
Yeah same here, would have loved to hear from someone who rode it against one of John's well set up Apex's. Oh well, probably too much snow in that region to do that !! Ha Ha..
The wait is on.
"The other demo was XTX LE in red and white. It had 15x137x1.25 ripsaw and had the fox QS3 Kashima coated shocks all around. These shocks are the real deal. Simply changing the clickers from 1 to 3 was very noticeable in the showroom."
Are you sure the QS3 kashima coated were in the rear also? According to the brochures, the XTX rear was different. It supposedly has an HPG back there as well. That was a deciding factor in choosing the LTX-LE instead (along with track, which on the XTX should be a backcountry 1.75. I didn't want that since I would like to stud.) Otherwise, I'm not sure what else justifies the $1k price differential between the 2 models?
Yes, you are right. Rear shock of skid QS3, center shock or front shock on skid HPG. Sorry for the descrepancy.
No problem, just making sure, expecially since I struggled with the decision of XTX LE 137 or LTX LE. Thanks for the report.
Yes,i understand john did all he could to try and convince the reps he should be the first to try one out,but they had no part of it,plus I guess the weather was so bad in caribou yesterday with the heavy wet snow,casuing power outages and stuff,you wanted to stay in side most of the time,and I don't even know if they started them up?
The demos were:
Hope this helps.
Were you able to lift up the sled,to see if it felt much heavier then a standard viper?
Never lifted a viper so can't compare, but I own a procross 1100 turbo and sidewinder felt roughly same weight. They claim SW is 10 pounds lighter and I believe it, but hard to notice that.
Also, the rep started it several times in the showroom and in my opinion it sounds like a viper/nytro 1050 motor.
I also noticed quite a bit of belt dust on the clutches on one of the demos. Rep stated Sidewinder will take same 8JP belt as viper. Searched this topic on the viper site and read 35 pages on the subject. It appears some viper owners had issues with this belt and changed over to the 8DN. Hope this isn't an issue on the Sidewinder.
My understanding direct from Yamaha was there was no Demos going on at any dealers..just display only.. so if they took these demos out, someone might be in trouble....
