upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Changed my clutch weights and put everything back together and my sled is now running rough...TORS or fuel relay?? I adjusted throttle cable to take play out...throws a TORS code (engine and 84) but only when I play with cable...I can get rid of code but still runs rough...could it be a bad fuel relay? Still have original one...it will run but won't idle...I'm stumped! Dealer is closed so I can't get a new updated relay today. Checked K&N's and changed the plugs...ideas? Messed up weather last few days...-15 to +10 while clutch was off.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Did you adjust the cable according to the manual pg 2-14? There is supposed to be some play or slack in in it.
upei93
- Apr 27, 2008
- Dalhousie, NB
Found the problem...engine is cooked.
canoehead
- Jan 14, 2011
- NE, Alberta
How? Thought all you did was a tune up, adjustment and some weights??????
TheKoning
Whats wrong with the engine!?
upei93
- Apr 27, 2008
- Dalhousie, NB
Conecting rod through the base of the engine...didn't do anything wrong...was running great...changed weights put clutch back on started and was running rough...thought it was TORS...tried to limp it to buddies heated garage up the road and rod came through base of engine...think middle piston spun a crank bearing...or could have been timing chain (I've heard of this??)...lots of oil..rod had a film on it...who knows? 13,xxx KM's on engine...Found a replacement engine with 6000kms for $2000.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Yikes, have a picture of this mess?
upei93
- Apr 27, 2008
- Dalhousie, NB
Will tomorrow when I start to tear it apart...anybody in the mood to do some wrenching...garage is heated! lol
upei93
- Apr 27, 2008
- Dalhousie, NB
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
If I lived closer I would come and help you. At least you have a heated garage (cold air coming back).
Pete
Pete
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
This happened to a friend of mine. His was caused by an oil leak which caused low oil pressure. Spun a rod bearing. Makes an awful mess. Installing the engine is actually not too bad. Just a lot of stuff to remove. A manual helps. If you can't find one let me know and I can email you one.
upei93
- Apr 27, 2008
- Dalhousie, NB
herndonp
- Nov 28, 2012
- Freedom,NH
Did you figure out what caused it?
canoehead
- Jan 14, 2011
- NE, Alberta
Has that machine been on its side or upside down while running? I don't see a roll over valve in your signature. Cheap insurance imo.
upei93
- Apr 27, 2008
- Dalhousie, NB
On its side 1000 klicks ago...top end is ok we think...crank bearing?
