Aren't those small Boostane bottles plastic? We have always been led to believe that if the Octane Booster comes in a plastic bottle it will not help Octane much.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
1 oz Boostane to 1 gal 91 oct = approx 95 oct
Per testing
I get the 32 oz and they are cans
Not plastic
Per testing
Not plastic
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
There's a lot of products that store better in metal containers. Fuel, Seafoam, boost additives, etc.Aren't those small Boostane bottles plastic? We have always been led to believe that if the Octane Booster comes in a plastic bottle it will not help Octane much.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Are you guys using boostane premium, or professional?
Doc Harley
- Oct 17, 2016
- Here & there
They are the same, and same container. Professional is the mix ratio for a little more octaneAre you guys using boostane premium, or professional?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
lol, well that’s dumb. You would think the people using this stuff can figure out mix ratios
Doc Harley
- Oct 17, 2016
- Here & there
Lol....it messed me up as well. I'm like, huh?!?!lol, well that’s dumb. You would think the people using this stuff can figure out mix ratios
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I don’t think it’s the same. I was just messing around on their calculator and to transform 10 gallons of 91 octane to 94 octane it takes 1.7 oz of professional and 2.4 of premium to do the same.
Doc Harley
- Oct 17, 2016
- Here & there
Idk?! I was using 91octane and .25oz per gallon. I like to round up. Similar to your 2.4oz. as I remember it's supposed to improve it three numbers or bring it up to 94 octane.I don’t think it’s the same. I was just messing around on their calculator and to transform 10 gallons of 91 octane to 94 octane it takes 1.7 oz of professional and 2.4 of premium to do the same.
It definitely shuts the deto off.
Was going to back it down to .2oz per gallon this year.
Why are you making things so difficult? You remind me..... Of me. Hahaha
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
They are not the same , the premium is street oriented with roughly a 100 octane capability. It is less potent and requires more oz per gallon to raise octane to a comparable level as professional formula. Professional has a capability of 116 octane and is more race focused.
Doc Harley
- Oct 17, 2016
- Here & there
Oh wow.... I'll have to go look and see how much .25 oz effects 91 octane. Probably not as much as I thought.They are not the same , the premium is street oriented with roughly a 100 octane capability. It is less potent and requires more oz per gallon to raise octane to a comparable level as professional formula. Professional has a capability of 116 octane and is more race focused.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
I use professional
At 1 oz per gal
I think it’s around 90 cents per gal more cost than pump gas but way more fun
At 1 oz per gal
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Would it be safe to assume that is a US gallonI use professional
At 1 oz per gal
I to stumble on ratio. I have to review what I was doing last year.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I made a spreadsheet for this (to convert back and forth to liters and ounces and ml per liter) if you are interested. But if you just want to be safe, (want to get to 93 octane for safety) then .5 ounces per 4 liters is a bit over 93 and per 5 liters is a bit under 93. .5 ounces per 4.5 liters is about the right spot but I would just use 5 to make the trailside calculation easy.
Choose File->Save As from the menus to keep a copy. I left it on the boostane page but that will probably change in the future
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Yes I would be interestedI made a spreadsheet for this (to convert back and forth to liters and ounces and ml per liter) if you are interested.
Is there any down side to over doing other than wasting product
- 8K
