jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
3/3 on that black tan? I got one to try this year with ultamaxBlack tan was my favorite spring to use and always what I ended back up with after testing others. Good choice, you'll like it.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Gonna depend on helix which You already know but 2-3 worked well with straight 35 and ultimax. Im guessing 38 or over youll be atleast 3-3. Initial pressure seems to be little less than black orange and good finish pressure. Seemed to cruise at lower rpm than black orange in my experience.3/3 on that black tan? I got one to try this year with ultamax
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The tan is stiffer that the B/O on the finish by quite a bit. When I tried the wrap on the tan at 50, it had less start pressure than the B/O at 90, and the tan had more finish pressure than the B/O on my drill press scale. The Tan is a pretty sought spring on the finish, bet be using a lot of helix angle with that one, which I know you do, but for guys with 37-35 finish angles on Dalton helix or stock helix, the B/O may be a better option. I don't think I'd ever wrap the tan up at 60, the finish on the scale is pretty extreme at that much wrap.
Myself I run the B/O at 90 with Hi-Torque rollers which roll much easier then any other roller I've tested on the scale, and rollers make a HUGE difference on spring/belt pressure in the secondary ultimately. Stock rollers in comparison need much less spring and roll very hard making of more belt squeeze on the upshift.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
What’s big pump?
Not pump gas?
lol. Seems to me that mine always liked a splash of something added
Not pump gas?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks Mike. Great info right here in your post. Yea I noticed on MS20 my belt started to slip up top with a 38 and the black orange wrapped 6/3.. ONLY time I ever had a issue up top was with MS20.. I rarely run that tune so maybe i will tune that tan on that tune.. I think its hard to beat that Dalton black orange at 6/3The tan is stiffer that the B/O on the finish by quite a bit. When I tried the wrap on the tan at 50, it had less start pressure than the B/O at 90, and the tan had more finish pressure than the B/O on my drill press scale. The Tan is a pretty sought spring on the finish, bet be using a lot of helix angle with that one, which I know you do, but for guys with 37-35 finish angles on Dalton helix or stock helix, the B/O may be a better option. I don't think I'd ever wrap the tan up at 60, the finish on the scale is pretty extreme at that much wrap.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Pretty sure they mean a bigger fuel pump then the stock fuel pump. The MS 17 lean which is what I ran @Bents you need a bigger/better fuel pump for..What’s big pump?
Not pump gas?
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
I got that. Haha
Anything over 270 hp is wise to add a bigger pump we thought when they came out in 17.
I’m saying I also add something to the gas with those tunes in n Wi because the 91 oct is probably more likely 87.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
BIgger pump should be a requirement for anything 270 and over IMhO
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Are you being serious? I was going to run the MS17 (280+/-) tune and TD says its not required!BIgger pump should be a requirement for anything 270 and over IMhO
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Knock protection will be your friend here.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
@jtmetal I run the 300 tune and upgraded the pump just a bit to a 190lph. I data log and it is almost always removing fuel. That said, I upgraded because I didn't want my pump to get a bit weak over time and put me in a bad place. I also haven't had long runs on a real cold night or with my 3" muffler now. Previously I had a Sandale stock modified 2.5". There is a big difference so it is possible I need all the pump can give now when all the stars align. If I added any other performance parts to mine I'd do the pump with regulator next.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
100 percent serious. ITs cheap especially if u don’t have data logging or an AFR module.Are you being serious? I was going to run the MS17 (280+/-) tune and TD says its not required!
I know what TD says and their not wrong but id rather be on the safe side hence why I saId
IMHO
I think someone crossed the stock one and it was like 130 lph out of a 4 wheeler
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
It’s ok and then it gets cold
Lol
Safe insurance
Lol
Safe insurance
Doc Harley
- Oct 17, 2016
- Here & there
Well....I haven't spent time dealing with the upgraded fuel system, I will work towards that.100 percent serious. ITs cheap especially if u don’t have data logging or an AFR module.
IMHO
Going to run my stock pump for a short time.
Snowdust, I am running a 3" muffler myself.
Good news is....I've got an upgraded intercooler coming. So that & a little boostane, mixed with knock protection and I should be good to go on short 1,200ft runs....maybe 1 or 2 runs to 2,000, just to see what's what.
Thanks for all the replies....I'm going to get that buttoned up!
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Lefthander chassis in Roscoe carries Boostane and have it in stock if you want to grab it local. It’s convenient rather than ordering
Just a fyi
Just a fyi
- 12K
