jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The fat lady called.. She said loosen that bitch up.
Jon i think the fat lady called and said dial that biatch in!
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Rednecks & DirtyHands running 1320'... always a fun guy to watch....and a reminder, to how much conditions play a role in your goal.
Fast
- Sep 25, 2018
Whats that dot way way behind them? looks like a polaris boostRednecks & DirtyHands running 1320'... always a fun guy to watch....and a reminder, to how much conditions play a role in your goal.
sideshowBob
Has anyone seen or heard of any head to head competition between the Boost and Ski Doos 850R turbo?
earthling
sideshowBob
Awesome! Thanks
sideshowBob
GPS run in the Video:
Speedo indicating a max of 202KPH or 125.5 mph
GPS Max 176.3 kph or 109.6 mph
Typical Ski Doo Speedo...over indicating by 15%
I guess the positive for the Ski Doo guys is they finally have an 850 that will break 100mph
earthling
The other videos I have seen have the boost leaving pretty badly on the doo but I think that is primarily setup at this point. With so little snow I don't think you will see any well setup comp-Rs until next season. Yes, the dream-o-meter is pretty bad on the doos.
Trailleader
114 in 500 ft
They’re getting faster
Haven't watched the video. They didn't use GPS to verify speeds?GPS run in the Video:
earthling
They do after awhile. 109 I think was peak.
We'll that's nothing to write home about.They do after awhile. 109 I think was peak.
Fleecer
- Jun 13, 2014
- 2019 SRX
I'm trying to compare those speeds to my winder. I'm not sure if 109mph is 1/3 throttle or 1/4 throttle. Can someone help?? LolWe'll that's nothing to write home about.
sideshowBob
In our group not a single Gade Doo 850 will GPS over 100mph so at least the 850R can do it...sad indeed that it takes a meth injected Turbo on basically bare ice.We'll that's nothing to write home about.
That Doo dream meter is as bad as my Attak's speedo was before I took 2 teeth off of the sensor gear but at least my Attak would run about the same GPS speeds as the 850R Turbo without a Turbo!
- 35K
