Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
And that sure helped!
Thanks!!
Thanks!!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
With a stock waste gate, and one of the "store-bought" tunes, remember the ecu is controlling boost (by controlling waste gate and using the tune boost level that it's programmed with). No matter how "good" or big your turbo is, your boost is same. HP improvements come from improvement in charge density, i.e. denser cooler incoming air, and the combined weight of these wheels is 12.5 grams (approx 7%) lighter than stock ones so the turbo spools quicker. When I ran my sled on the same track dyno before and after the turbo mod, to run the same AFR, I had to increase my fuel pressure about 5 lbs.(even at higher ambient air temp). That told me that the incoming air density was higher.
If you have a tune with no ecu boost limit (race map), then the mod stock turbo does produce more boost and therefore more HP.
Last winter I was hitting the set boost cut off point at part throttle with cool intake temps.
Having the secondary intercooler with a fan and shroud on it. Boost sensor is before throttle plates. Would like to have that boost limit raised at part throttle in the computer.
Always pushing the limit of the tunes.
Wastegate controller and fine tuning option in the app TimLast winter I was hitting the set boost cut off point at part throttle with cool intake temps.
Doc Harley
- Oct 17, 2016
- Here & there
Tim, this might help.
Doc Harley
- Oct 17, 2016
- Here & there
Did a little tuning today. I had to start two barrels back and when I hit the second barrel I went wot....those were the best conditions, couldn't get traction from the dig!
Had to put two more grams of weight in clutch, play with fuel pressure, Yada, Yada
Turbo Dynamics MS17
15.3mpg
76.2g @ 8900
Afr 11.6
Boost 17.6psi and held it.
I'm running/tuning in 36°. So everything should be alot closer at 10°. rpms go up, afr will settle in.
But I have to say....she's pretty stout.
Turbo Dynamics MS17
15.3mpg
76.2g @ 8900
Afr 11.6
Fords4life
- Dec 7, 2021
- South Dakota
Sure is a nice looking sled...hard to beat yammmy blue and white, also like the control arms level with the world, keep digg'n old friend.Did a little tuning today. I had to start two barrels back and when I hit the second barrel I went wot....those were the best conditions, couldn't get traction from the dig!
76.2g @ 8900
Afr 11.6
I'm running/tuning in 36°. So everything should be alot closer at 10°. rpms go up, afr will come down.
Doc Harley
- Oct 17, 2016
- Here & there
That you for the kind words and wisdom, in initiating the work done on my turbo!Sure is a nice looking sled...hard to beat yammmy blue and white, also like the control arms level with the world, keep digg'n old friend.
BTW...still have a couple things I'm working on. Lol. But this wasn't the trip for that.
Need to get a baseline on things moving forward.
Thank you, fords4life
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
What lake are you running on?
Doc Harley
- Oct 17, 2016
- Here & there
Sunrise lodge on Lac Vieux DesertWhat lake are you running on?
Doc Harley
- Oct 17, 2016
- Here & there
Hmmm.....these didn't last long. Is there something a little more robust to replace them with? Appx 600 miles....and a few good pulls.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I’ve had good luck with these bushings.
- 90380-09245-00
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Who's are those? Just tried Thunder products, look the same, same miles.Hmmm.....these didn't last long. Is there something a little more robust to replace them with? Appx 600 miles....and a few good pulls.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You need an Apex clutch Doc. I used to go thru a set every weekend. Switched to an Apex clutch and problem solved.Hmmm.....these didn't last long. Is there something a little more robust to replace them with? Appx 600 miles....and a few good pulls.
I have used Thunder Product rollers for many thousands of miles on my SW and they have stood up well but I have pretty well always had an Apex clutch on it.
- 11K
