2000ft speed on zx2
sneakattak88
sudbury ontario
OK need a few ideals,, i have an turbo Attak, i have the boost figured out the fuel the clutch, lOL evrything but the skid, Its a 136 ZX2 , im dropping the front float shocks,, but have no clue about the rear, for a weekend of 2000 ft of ice drags,, any ideals on set up, oh i weight 180 lbs,,, shocks strap and pins,
In the manual I remember reading about the pin settings and for coupling they actually said to use one of the settings for drag racing only or smooth surfaces like ice, I cant remember how they worded it.
I drop mine and the skid goes way up in the air. Not sure how to push it down and hold it. The pins only have a top speed setting in the book. I may strap it down but not sure if it will break.
Can you put fox floats on the back of a ZX2? I back the springs right off. It sinks good. I have cut drag front springs. The profile angle is flat to the rail. We will see what she will do.
powder muncher said:
Shorter shocks....
I know you can get Fox Floats in any length you want thought about doing that on mine.
I do not, I will have after sunday. All I did was take the old springs and cut a 2" section out And weld it back together. For the back of the ZX2 just back the springs off to the lowest setting. Get 2 people to sit on it and tie in place. It will be low. I can't wait to see if top speed goes up.
